Thread: Perhaps a strange question. Pool water safe to drink?
    epro05's Avatar
    Jun 2014
    Keller, Texas
    274
    Here's the scenario: Home water supply is cut off due to broken pipe and plumber can't come for a few days.
    Would it be safe to use pool water for drinking/cooking if the water is balanced e.g. CYA=80, FC=9, CC=0.5 or less, and other parameters also balanced.
    If not a yes/no question, what are the other considerations?
    Thanks for your input on this.
    27,500 gallon in ground gunite/plaster (1995). Attached Spa with fountain, spillway, and 2 lion heads streaming into the pool. Hayward pump and AO Smith UST1152 1.5 hp motor (single speed). Hayward 60 sq ft DE Filter (Model DE-6000). Kreepy Krauly cleaner.
    Richard320's Avatar
    Jan 2010
    San Dimas, CA (LA County)
    19,075
    Re: Perhaps a strange question. Pool water safe to drink?
    No. Not safe. Good for flushing toilets, though.
    The drain on your water heater should provide you with enough drinking/cooking water.
    epro05's Avatar
    Jun 2014
    Keller, Texas
    274
    Thanks Richard,
    But I'm wondering why it's not safe, since it's chlorinated. Is the CYA the problem, or what else?
    Jun 2011
    Long Beach, CA
    2,790
    Short summary: if pool water is all there is that you could conceivably drink, than it probably isn't that bad. But if you have any other plausible choice use it instead.
