Results 1 to 15 of 15
Thread: Retractable Awnings
    Retractable Awnings
    Anyone have any experience with retractable awnings?
    I am looking for a 22' x 10' or 12' model. Our backyard faces west and we get a lot of sun from noon to 6pm but the problem is the height of my covered patio does not provide much shade when the sun is in the two o'clock position and later. The patio is 35' x 10' and the ceiling is 10' high.
    20x40 24,000 gal IG plaster/CircuPool RJ45 SWG/2 skimmer/2sp 2.5hp Jandy Stealth/340sq ft cart filter/600sqftHeliocol Solar Panels/6ft semi circlr tanning ledge/25ft deep end bench/5ft sheer descent/2 lion head water features/1300sqft travertine paver/2 Colorlogic lights/Hayward Navigator/3step 2ft raised bond beam
    TizMe's Avatar
    Aug 2007
    Covington, Georgia
    920
    Re: Retractable Awnings
    Have you thought about doing an arbor type thing over that area and perhaps letting a vine typ plant grow aver it? It would provide shade in some degree but not totally close off the area. Im not sure how expensive retracting awnings are.
    Les
    Don't have a pool right now. Just sharing what I have learned over the years!
    Helpful Links:
    Pool School,Pool Calculator,Cl/CYA Shock Chart,TF Test Kit
    Doing BBB and loving it!
    frustratedpoolmom's Avatar
    SWSuburban Chicago, IL
    11,969
    My experience with retractable awnings is limited to the type on RV's...tho I think a few of the companies do both types, like A & E and Carefree are two that come to mind. You get what you pay for....you want the kind that will dump the rainwater without having a puddle in the middle that can bend the main support roller. There are also types that have wind sensors that will retract automatically if it gets windy, so that's something to consider, if you plan to use it for anything other than as a sunshade. Definetly do as much research as you can ....consider other options, as they are not maintenance free, and you can get mildew problems.
    AnnaK's Avatar
    Jul 2007
    Eastern Pennsylvania
    1,134
    We have one over our back deck. It's nice but really only provides limited shade, depending on the position of the sun. I open it part way nearly every day to shade the patio door which keeps a lot of heat out of the family room. When it's fully extended wind can be a problem, even a light breeze, but we rigged a couple of tie-downs involving small flower pots filled with Quickcrete, PVC pipe, snaps and eye bolts which do a fine job holding the awning even on a breezy day.
    No problem with rain collecting because . . . well, we don't open it on a rainy day. No sun, you know? No problem with mildew, either, since the fabric is treated. Our awning is about 8 years old and looks like new, no wear and tear, no fading, no mechanical failures.
    AnnaK
    12,500 gal AGP, Hayward sand filter, Pentair 2-speed pump, timer.
    Please visit our Pool Issues pages for information about step weights, managing the solar cover, and PoolSkim.
    Guest
    The former owner of my house had awnings in a couple of places. One was in bad shape, so I replaced it with this: http://www.thenaturalhome.com/shadecloth.htm
    The other awning is OK but when it dies I'll replace it with the shade cloth also. I have black 80%; next time I'll order black 90%. I got it for a few inches smaller than the existing frame and just laced it up on the existing frame. It has gromments every 12" and it looks great. The former owner had an awning company install and remove the awnings every year; the awning company has terrible service and they power wash the awnings (so they don't last very long!). I got rid of them quickly.
    I had a similar product at my previous house but a different manufacturer, Hendee Enterprises. That one was heavier and looked new after 5 years of use. It was only about 10' x 12', green 80%. I had it made with pockets in 2 opposing sides and put an aluminum rod in each pocket, then threaded the rods into eye-bolts mounted on one roof and hooks on the opposite side (deck wall).
    Regular awnings last about 5-8 years, but in the North East, you leave them out for half the year in all sorts of weather. A friend has a retractable and likes it but said that it was very expensive, $3k or so if I remember. She said that if she'd known about the product I used, she would have done that. Mine cost under $125.
    Sue
    No P in my ool's Avatar
    Jun 2007
    Logan IA
    219
    The Home Depot carries Awntech awnings. You have to order online. I have one and am very pleased.
    https://www.awntech.com/xcart/product.p ... 266&page=1
    21' Leslies Beachland Ag Pool, 10,000 gallons, professionally installed (best money I ever spent) Hayward 16" sand filter w/Pentair two speed pump Fafco 4x20 solar heater,Aqua Trol RJ. Borates added. Hard plumbed.
    Thanks for all of the responses.
    I thought about doing an arbor but not enough shade, if I go the vine route it would be almost over the pool and I do not want plants over the pool.
    Shorelover Is that a fixed awning? I need about a 10ft projection (length of the awning).
    Guest
    My current house has an aluminum frame that is permanent (fixed) above the deck that has a southern exposure. I put the sunscreen on this spring and plan to remove it next month; I like the sun during the rest of the year. I laced it using twine but also used a few cable ties; took less than an hour and cost around $100 (an awning would cost many times that and I'd have to deal with an awning company that wouldn't show up when they're supposed to [I've heard nothing but bad about the local awning companies and my one experience was bad]). It arrived less than a week after I ordered it.
    At my previous house, I had a 6' deck wall (also southern exposure). The sunscreen went from that wall up to the edge of the roof. I think it was 10' or 12'. I left it up from about May until mid-September.
    I guess that you could leave them up all year long since you don't get much snow. They recommend parachute cord that you can get from an Army/Navy surplus store. Rain of course goes through them, so there's no ponding like there is on the regular awning. You could of course install it over an arbor. It could either be laced on through the grommets like my current application, or you could do it the way I had it at the previous house (have pockets made on opposing sides when you order it that go the full length, then run an aluminum rod through and attach using eyebolts and / or big hooks). There's a picture of one stretched on a pergola on the link I provided above (towards the bottom of the page).
    Just noticed your location -- go to any garden store / plant grower and you'll see these sunscreens used. That's how I got the idea at my previous house -- I was at a garden store and looked at the manufacturer of their shade (Hendee) and ordered one.
    Sue
    Quote Originally Posted by No P in my ool
    No P,
    How long have you had yours and what are the specs? Do you have issues with wind?
    I saw these on BJs Wholesale and Costco's website.
    Jun 2007
    Logan IA
    219
    Just got it this summer. With winds I don't extend it all the way. They sell "breeze poles " but they want to much money for them. I am going to make my own. These awnings are rated for winds up to 35 mph. My awning is a 14 by 12. Spend the money and get a motorized model. It comes with a remote and is well worth it.
    Aug 2008
    Pensacola, Fl
    58
    Check out Sunsetter Awnings. My pool and back of house also gets western afternoon sun. We got one from them about 2 or 3 years ago. 18 wide X 10 out from house. Hand cranked. I only roll it up for tropical storms and hurricanes. I installed it myself with small amount of help from my wife. We also got the 'hang-down' screen to help block the intense afternoon sun.
    About 23,200 gal vinyl in ground, "stop sign" shaped 22x22, Polaris 3900 cleaner, Hayward Aqua Plus Pro Logic Controller, Hayward T-15 SWG cell, Hayward S244T sand filter.
    Round Rock, TX
    529
    I have the Sunsetter also, but it has a motor and a remote control. So we can control it from inside the house. My back yard also faces west and the afternoon/evening it gets very hot. I bought mine at Costco about 5 years ago.
    When I installed it, I installed it into the bricks on the home. After about a year it started pulling the bricks out of the wall! These are the "soldier" bricks that lined the top of the wall. I took it down, and moved it up a foot to the wood siding, fastened it into the studs and have had no issues with it since.
    dave
    15,500 gal, inground gunite pool with 7 ft spa, 2 speed pump 2hp/.33hp, 3/4 hp booster pump, Intermatic P1353 timer, AutoPilot SC-48, Sand filter with ZeoBest, Heater, that I never use . . .
    I have been doing research and have narrowed it down to two models.
    Awntech - has larger sizes that I need (ranging from $1600 20X12 or $2000 for a 24x12) and the fabric is acrylic which they say is better (Sunbrella is acrylic)
    Sunsetter- Costco has a 30% off sale, a 18X10 is $1100 shipping included. The fabric is vinyl, shich some same it can get mold and mildew. Sunsetter also has customer complaints about their service and support, not the product.
    I would like the Awntech but Costco's sale is hard to pass up. Has anyone had issues with the Sunsetter brand?
    Aug 2008
    Pensacola, Fl
    58
    I have the Sunsetter 18x10 hand cranked model. I had a gear strip out, but they replaced it no-charge with one toll-free phone call. The person on the phone at Sunsetter did acknowledge that it was a known problem. Other than that, no problems at all. As I said before, mine stays down for use, and I roll it up for tropical storms and hurricanes.
    monkeywrench's Avatar
    May 2008
    Shrewsbury MA
    84
    I too have had a manual crank sunsetter for the past two years. Installed it my self with a little help
    from the wife. They have accessories to control for high winds and bugs.low sun etc.
    I also ordered the lighting kit which came poorly packed and some of the ceramic sockets were
    broken, They sent a whole new set out no questions asked and didn't want the old ones back.
    I fixed them easily and now I have two sets
    We love it. Its like having a whole new room outdoors.
    jb
    14x28 IG Vinyl
    12.5k gal
    Hayward SP-Super Pump
    Hayward Pro-Grid 36sqft DE
    Hayward auto chlorine feeder (offline:using BBB)
    Hayward AG Gas heater
