Thread: Noisy Pump Motor
    Noisy Pump Motor
    This is the circulation pump for my hot tub. It's a Hayward Super Pump 2. The motor is at least 14 years old and just started making this noise a few weeks ago when it got cold (for us) here in Dallas. I made a Youtube video of the pump running. I think it may be bad bearings.
    https://www.youtube.com/watch?v=gJW_...ature=youtu.be
    Thanks for the help
    I got nothing right now
    mas985's Avatar
    Pleasanton, CA
    11,741
    Re: Noisy Pump Motor
    Sounds like bad bearings to me too. You can either replace the motor or just the bearings if you are willing.
    Mark
    Citizen's Avatar
    Oct 2014
    Orlando, FL
    92
    Replacing a bearing can be a tricky process, below are a few links on hos to get it done. The first two are text links and the third is a video:
    How To Replace the Bearings in a Pool Pump Motor - Part I
    How To Replace the Bearings in a Pool Pump Motor - Part II
    https://www.youtube.com/watch?v=Jc8U1dWuSwo
    Jan 2015
    South Lake Tahoe, California
    11
    Jooky, Replacing the bearings should be a good project for you. Do it soon before it spins the bearing. Let us know if you do it. They're not hard, the motor's gone if you don't. You can do it!
    Richard
