Results 1 to 7 of 7
Thread: Jandy Aquapure 1400 malfunctioning
    Jan 2015
    Punta Gorda Florida
    2
    Unhappy Jandy Aquapure 1400 malfunctioning
    Hi
    I'm a newbie and trying to diagnose problems with my AquaPure 1400/PureLink RS system. Upon seeing gen. fault warning, on my interior panel, I went to outside panel and found fault codes 170/187. The only lights on were power, cell reversing and service.
    I then took readings on back board as follows: 1-8 = 80
    2-7 = 69
    3-6 = 21
    4-5 = 0
    Going further, I did the diagnostics on the front board: Salinity & R temp + Key C = 00
    Salinity & R temp + Key D = 66
    H temp + Key C & Key A = 66
    From what I can gather, my front board is JUNK, but before I invest I thought I'd get some other opinions. I'm also questioning the wisdom of continuing with this system (it's about 6 years old) as I my also have cell and sensor problems. Any recommendations are greatly appreciated, as I read that this is not the most reliable system.
    Thanks
    Jun 2011
    Long Beach, CA
    2,790
    Re: Jandy Aquapure 1400 malfunctioning
    Welcome to TFP!
    It is testing like the board and/or the transformer is bad. I dont' think the Jandy Aquapure has had too many problems with the boards, their main problem was with the tri-sensor.
    If you decide to switch brands make sure that it will work with your automation.
    Jan 2015
    Punta Gorda Florida
    2
    Ping
    Thanks for input. My cabinet has two transformers, a large one on left and a smaller one on right. Do you know which is supplying the SWG
    Mitch
    Jun 2011
    Long Beach, CA
    2,790
    No, you need to trace down the wiring if you can.
    Oct 2007
    Parkland, FL
    752
    I trouble shot mine just a couple of months ago, for the transformer, you just follow the big white plug on the board back to the transformer, the board and transformer are available online.
    If you PM me, I'll try to find the troubleshooting guides on my phone and email them to you.
    8000 gal diamond brite pool with 650 gal spillover spa, Pentair 3hp VS pump. Jandy Cartridge filter and Jandy Heat Pump. Jandy PDA automation system with 2 Pentair Laminars. SmartPool NC74S Robotic Pool Cleaner.
    dayhiker's Avatar
    Jun 2008
    Pell City, AL
    304
    I'm in the same boat. I replaced my salt cell in early summer and by mid-summer was getting error codes indicating the board. I did the same tests and it looked like my front board was toast. I decided to get through the summer by using bleach and then decide what to do. It would be easier to just replace the boards but I also wonder if now isn't the time to just change to a different system. I've changed the sensor multiple times since it was installed in late 07. I wonder how much longer the system will be supported?
    The avatar is Spalding from Caddyshack
    18x36 vinyl IG - approximately 24000 gal
    Jandy SHPM1.5 Pump (1.5 HP); Jandy APURE 1400 SWG; Polaris PB4-60Q Booster Pump; Jandy CL340 Cartridge Filter
    (3) 4'x12' Aquatherm solar panels
    Next project, pump sound enclosure and lots of pool landscaping [6tons of stone 8) funnnn]
    Oct 2007
    Parkland, FL
    752
    I have troubleshooting manuals for the old style with square cell and new style with round cell. A monkey with a voltmeter could diagnose these. I am happy to send to anyone if they pm me their email address.
    It appears your transformer is okay from the readings you got. 4-5 should be 120mv but I'm guessing it wasn't producing chlorine or the meter wasn't set up right. you will need to troubleshoot the front board.
    Quote Originally Posted by trlman View Post
    Hi
    2-7 = 69
    3-6 = 21
    4-5 = 0
    Thanks
