Results 1 to 14 of 14
Thread: Strongly considering SWG
    mitch08's Avatar
    Jun 2008
    Suffolk County, NY
    370
    Hey all.
    After years of resistance, I think I'm finally fed up with dumping bleach and pucks into my pool
    So highly considering a SWG at the start of this swim season. Just have a few questions...
    I run my pump / filter 24/7 May - September. I know its overkill, but Ive done it for 10 years and am very comfortable with maintaining it this way.
    Will doing this become an issue with a SWG? Is there an issue with burning out the cell quicker because of this?
    My pool has an attached spill over spa. Before switching to bleach a few years ago I used a chlorinator. The problem I was having was that when I switched to spa mode, the chlorine level in the spa became much too high. So when switching to spa mode, I had to turn the chlorinator down to its lowest setting or off completely. Will this also be an issue for a SWG? If so, is it possible to turn it off or down so the CL level in the spa doesnt get out of hand?
    My last question is a little silly but a concern. Ive swam in a few SWG pools and they had a very heavy taste of salt. Even though I know we arent supposed to be drinking the water, it was pretty gross Are there SWGs that require less salt? My thinking is less salt will equal less salty tasting water? Is this somehow controllable?
    Thanks a million everyone!!!
    18x38 Inground Liner (25k gal) Paver surround, multi-speed pump, DE Filter, Raised spill over spa, TF-100
    Jun 2011
    Long Beach, CA
    2,790
    Re: Strongly considering SWG
    No problem running 24/7 with a SWG, you just turn down the SWG % on time.
    If you have automation, the SWG can be set to operate at a lower level automatically while in spa mode. I don't have automation and when I turn my valves to run in spa mode I just turn the SWG down to 0% and then turn it back on after we are finished with the spa.
    Most SWGs in the USA use about 3000/3500 ppm of salt while some others do require 4000+. The less amount of salt in the water means you will not taste it as much, but the SWGs do need a minimum amount and that tends to be 3000 for most units.
    Running the pump 24/7 is no problem. You will be able to run the SWG at a lower percentage setting and the SWG will last just as long as usual.
    Do you have an automation system? An automations system will take care of turning down the SWG percentage when in spa mode automatically. If you don't have an automation system you will need to do this manually, which can be mildly annoying.
    Nearly all of the current crop of SWGs require salt levels around 3000. Most people don't find that objectionable, but that varies. Some older units required higher salt levels. I don't know of anything that works at lower salt levels.
    mitch08's Avatar
    Jun 2008
    Suffolk County, NY
    370
    Thanks so much guys!!! Appreciate it. I do not have automation. But that is not going to stop me from moving forward. The annoyance of turning down the SWG can't possibly be greater than the annoyance of pouring endless amounts of bleach into the pool
    No issue with concrete pavers right?
    Concrete is just fine around the salt levels used with a SWG.
    38,532
    I know you say you are comfortable with it, but would you be more comfortable with $$$ in your pocket?
    24/7 is certainly overkill, 6 hours is likely plenty. But, if you want to run all the time, I would hope you have a 2-speed or VS pump and are running it at low speeds. You could likely pay for your SWG within a year or so by reducing your run time and paying less for electricity.
    Please add your location (City, State or City, Country) to your profile as described HERE as it will help us help you.
    mitch08's Avatar
    Jun 2008
    Suffolk County, NY
    370
    I do have a 2 speed pump, but I keep it running at 2.5 all the time instead of turning it down.
    I completely understand Im wasting power and $$. But I like the fact that my water is always circulated.
    38,532
    Fair enough ... I would recommend checking out this article if you have not already:
    http://www.troublefreepool.com/conte...-pump-run-time
    There are links to the study that are referenced in the article posted on the forum (somewhere ...)
    Divin Dave's Avatar
    Oct 2013
    Longview, Texas
    5,025
    For whatever its worth to you. I keep my salt level at about 3000-3200 ppm. At that level you can taste the salt a little, but I wouldnt say it was overly salty tasting and certainly not grossly so. Of course everyones tastebuds are a bit different...so.... your mileage may vary.
    Divin Dave,
    Jul 2014
    Peoria, IL
    389
    I have a SWG inground pool and I run my pump 24/7 from May-September. I have no spa or automation so I find that it is easier to run it 24/7 than mess with timers trying to turn on/off both the pump and SWG and heater etc. I am on 3 years and no issues yet.
    30x20 vinyl IG, Hayward SD60 with Pentair Dynamo 340219 2HP pump, Compupool CPSC24 SWG, Hayward H200FDN heater. APC automatic pool cover.
    Central Illinois
    mitch08's Avatar
    Jun 2008
    Suffolk County, NY
    370
    Quote Originally Posted by bdex View Post
    Thanks. So you just keep the % down? Thats exactly what I will be looking to do.
    Jul 2014
    Peoria, IL
    389
    Quote Originally Posted by mitch08 View Post
    Yep. In April/May when I open I pretty much SLAM it with LC to get the FC levels up. Then I keep my SWG at about 70%. Where you keep your SWG set depends more on the capacity of your cell and the size of the pool.
    Always oversize the cell pretty significantly. I have a 22,000gal pool and got a 24,000 cell and wish I had done the 36,000 cell.
    I keep a case of LC in the garage and when it gets really hot and sunny and the pool gets used a lot I will sometimes dump a little in to keep the levels up and save the cell. I never use the super chlorinate.
    We have an APC automatic cover that helps dramatically.
    Central Illinois
    aussieta's Avatar
    Jan 2014
    Langwarrin, Victoria, Australia
    492
    yes, as mentioned get a cell at least 1.5 times the size of the pool if not 2 times the size
    cells are rated with pump running 24/7 and then only just cope
    SWG inground peanut shaped eco-bright concrete pool
    50,000 litres 13,000 gallons
    Lincoln Salt Chlorinator, 25 gram cell Sand Filter with glass media
    Taylor K2006-C test kit, Taylor K-1766 salt test, Dolphin M500 pool cleaner
    are you taking care of your pool or is the poolshop taking care of you
    n240sxguy's Avatar
    May 2014
    Benton, KY
    1,801
    As others have said, salt pools will taste different to everyone. I swear mine tastes like sweat when I first get in it. After a minute I don't notice.
    30K gallon IG vinyl. 1.5HP 2-speed Waterway Mustang pump. 600 lb sand filter. Polaris 280. Circupool SI-60+. TF-100
