Results 1 to 19 of 19
Thread: Pool Heating in Central Florida
    Nov 2014
    Dade City, Florida
    94
    We have an above ground 18X33 pool coming soon. The pool holds about 14,000 gallons. We are snow birds and will use the pool from late August to early May. I guess my first question is whether we need a heater at all. There are some nice plus 70 degree sunny days in the "winter" here when we would like to use the pool. From what I've read it appears that a heat pump might do the job for us. If so how big a heat pump do we need? Not sure which direction the house faces for solar panel use. We use propane to heat our house in Pa in the winter and there is alot of price gouging up there so my inclination is to stay away from propane not to mention that it costs almost twice as much in Florida ! . There is no natural gas here.
    ps0303's Avatar
    Jul 2011
    FL
    3,701
    Re: Pool Heating in Central Florida
    Do you plan on keeping it heated all the time or only for say weekend swim?
    Paul
    http://www.gastekservice.com A word of caution: When working with gas and electrical you might want to consider a licensed contractor. Consider the value of your life and others around you. If you would like to provide a review of the help I provided, please use the following link to leave a review. gastek - Google Search,
    Nov 2014
    Dade City, Florida
    94
    Quote Originally Posted by ps0303 View Post
    I guess that depends on the cost to heat it. We do have nights where it goes down into the 30's and I'm sure that would knock down the temperature quite a bit. We wouldn't use the pool every day. I will be using a solar blanket.
    ps0303's Avatar
    Jul 2011
    FL
    3,701
    You won't get much heat out of a heat pump once the temps get 60 or below. If you are looking to be able to say start heating in the middle of the week to swim for the weekend, a heat pump is going to need much more time that that. I would have to say in your case, above ground pool which doesn't give you any thermal protection because it is above the ground, you really might want to consider propane. At least with propane you can get a better on demand heating.
    Paul
    38,415
    It is also nearly always cheaper to heat the pool up for use (like on the weekends) and not heat it during the week when it is not used. You would want the faster heating from gas though.
    Nov 2014
    Dade City, Florida
    94
    Lets suppose I run the heat pump constantly. Would it maintain a constant 86 degree pool water temp after taking days to get it up to that level? And if it could would my electric bill go through the roof? Any members using a heat pump in Central Florida? If so, could you please share your experiences?
    Citizen's Avatar
    Oct 2014
    Orlando, FL
    92
    Dave, I would suggest messing around with this Raypak heat pump calculator to give you an idea on cost. The costs are averages and will show "Best Case Scenario" type pricing but it will give you a good price ballpark:
    http://roxwebdev01.pixelgate.net/gas...ak.php?appid=1
    Nov 2014
    Dade City, Florida
    94
    Quote Originally Posted by Citizen View Post
    Good stuff Citizen. Propane is much more expensive and thats why I shy away from it. What do you use in Orlando?
    ps0303's Avatar
    Jul 2011
    FL
    3,701
    You mentioned earlier that propane costs were twice as much in FL as in PA. Are you sure about that?
    Even though the cost to heat with a heat pump seems cheaper, you will have issues if you do any "quick" heating functions.
    I've pulled many a heat pumps out because they just don't do it for some customers. But I'm sure some heat pump guy will say the same for a gas heater.
    Paul
    bobodaclown's Avatar
    Apr 2011
    Murrieta, CA
    2,360
    Is solar an option? With a heat pump?
    http://www.fsec.ucf.edu/EN/consumer/...ools/index.htm
    If you're not using a cover heating a pool is like heating the house without a roof.
    Nov 2014
    Dade City, Florida
    94
    I will be using a pool cover. I guess solar is an option. At this point not sure which direction my house faces. Its a manufactured home so not sure how much weight the roof will bear. I do have a large back yard so there should be room for panels on a rack. Just bought the pool so money is too tight for two separate systems. I see that you have a 100K heat pump bobo. Does it do the job for you?
    Apr 2011
    Murrieta, CA
    2,360
    I use it to extend the season or to begin early. Nov/March. I don't have a pool cover. Water currently is 64.
    Nov 2014
    Dade City, Florida
    94
    I know that a propane heater will give me "quick" heat. But I'm thinking it might be more economical to just wait until say March 1 and then turn on the heat pump and pretty much leave it on till early May when we head back up north. Then turn it on again in October and use it into November/December again leaving it on.
    The propane cost in Pa was $2.15 a gallon at my last fill in October 2014. The $3.59 a gallon was the price I was quoted yesterday here in Florida.
    Quote Originally Posted by bobodaclown View Post
    Sent from my ALCATEL ONE TOUCH Fierce using Tapatalk
    Thats how I'm thinking of using one too. How did you decide on 100K BTU? Pool supply place recommended 85K BTU for my 18x33 pool which I think will hold 14-15,000 gallons. A little less than yours.
    Nov 2014
    Dade City, Florida
    94
    Apr 2011
    Murrieta, CA
    2,360
    Hi Dave, I inhered the "dead" heat pump when I purchased the house. The owners said it didn't work, the home inspection said it was dead, so I thought it was dead. I did some research, found some trouble shooting videos, got out my multi meter and went to work. Turned on the pool pump, kicked on the main breaker, turned it up to the highest temp setting, was taking offer the cover to the power connector, about 3 minutes had passed and low and behold the unit kicked on. Read that there was a 3 minute lock out on the unit to prevent short cycling. Score!
    Oct 2007
    Parkland, FL
    752
    You would be better off with gas heating, your bill will be 500 plus trying to use a heatpump during the winter, been there and done that in south florida. Its the pump that will raise up your electric being run 24/7 to try and keep the temperature up. Natural gas would probably be the best bet.
    8000 gal diamond brite pool with 650 gal spillover spa, Pentair 3hp VS pump. Jandy Cartridge filter and Jandy Heat Pump. Jandy PDA automation system with 2 Pentair Laminars. SmartPool NC74S Robotic Pool Cleaner.
    Nov 2014
    Dade City, Florida
    94
    Good job Bobo, you're my hero !
    Quote Originally Posted by robl45 View Post
    Natural gas would be great but unfortunately not available where we live. Only propane which is very expensive.
    Oct 2007
    Parkland, FL
    752
    Quote Originally Posted by Dave2590 View Post
    Yes, I had propane before I put in a heat pump at the old house, in ground tank that the previous owner left part filled, I got quotes and never did fill it up again. Still the heat pump at cooler temperatures is rediculously inefficient and the more you run the pool pump, the higher the electric bill goes.
    Just heating my spa at night now with 65-70 degree air temps takes over an hour and a half.
    ps0303's Avatar
    Jul 2011
    FL
    3,701
    Shoot after 30 minutes I would have given up. Most people want it heated in 10 minutes.
    Paul
