Results 1 to 10 of 10
Thread: Rivet question re grab size and question for those who didn't use rivets...
    Jun 2014
    Lake Jackson, Texas
    133
    I'm still on the fence on whether or not I am going to use rivets. I purchased an air powered rivet gun just in case I do but my questions are...
    I see everyone saying to use 1/8" rivets, but what grab size are you using? In particular, I plan on using the 10 x 10 L straps on the overhang so I want to make sure I get the right grab to go through those. I plan on using 20 gauge studs.
    Second, for those of you who did not use rivets, did you have any issue with your board not going on straight? Since so many do use screws I suspect this is not a problem but did run across a couple of threads on the net saying it is. I can see a slight time advantage of using the screws but really drilling a hole for a rivet is no big deal and taking one out is about the same time and you still have a usable hole to work with.
    Aside from the longevity and not backing out, are rivets truly stronger than the screws?
    Getting close to starting a build. I have the grill on hand a door on the way and also ordered a side burner, another door, and a drawer setup today. I'm going to try and pick up the metal studs next week. Still have some stuff to do around the house before starting another project...
    If it matters, I'm going to use 1/2" Wonderboard Lite all around since I have a bunch here for a flooring project I am working on and need to switch that project to 1/4". I guess I could always bring it back for exchange but since it is here, might as well use it right?
    25K gal FF; QuartzScapes Barbados Blue; ColorLogic LEDs, ProLogic PS-8, AquaPod, AquaConnect, (3) WhisperFlo 2.5HP pumps, 1HP blower, 3/4HP cleaner pump; Pentair CC 520 cartridge filter; MasterTemp 400 propane, Rainbow 320; UltraPure UV/Ozone; Polaris 280; 7' raised spa by rock waterside; (soon) 62" fire pit, (soon) ODK; 60x40 screen enclosure
    Build - here.
    Patrick_B's Avatar
    Jun 2011
    Midland TX
    14,998
    Re: Rivet question re grab size and question for those who didn't use rivets...
    Absolutely, by all means use it.
    Essential Links:
    Jun 2014
    Lake Jackson, Texas
    133
    That's what I figured, thanks! From what I can tell on the rivets, I'll need two sizes... 1/8" x 1/8" grab for the normal stud construction and 1/8" x 1/4" for the spots with the L straps. This is assuming the 20 gauge steel I get is .031 thick. The L strap is .074. Meh, I'll eventually figure it out, just being lazy hoping someone already knew. Lol
    Build - here.
    Riles_J's Avatar
    Nashville, TN
    218
    I started using rivets, and had a pneumatic rivet gut that never really worked for me. Probably because it was a real cheap one. As a result I switched to screws and they were so much easier. Not more broken drill bits from pre-drilling and the riveting was just a lot harder for me. It did create a slight unevenness to it but depending on what you are skinning it with all of that gets covered. I used stucco on the sides of mine, where I used screws, and I had no issues at all as the stucco is troweled even. I can't think of any covering that the screws would create problems for. Stone veneer seems like would have even less of an issue. That being said I did drill and hand rivet the top. I guess I was fearing it might cause my concrete counter to have some artificial point loads. So I guess I used both. I think whatever you are comfortable using will work. Don't overthink it
    Riles
    16x32 IG vinyl, 19,000 gal, 1.0 hp pump, sand filter, 2 returns, 1 skimmer, diving board, slide
    Jun 2014
    Lake Jackson, Texas
    133
    Thanks Riles, I always overthink it... I'm comfortable working with either so I may choose to go the quicker way, screws...
    Build - here.
    Mar 2014
    Ca
    33
    I used screws just because I didn't want to drill all the rivet holes. I used about 1000 screws and glad I didn't have to drill 1000 rivet holes. Screws will be easier and just as strong.
    pragmatic's Avatar
    Jul 2011
    Friendswood, TX
    521
    A bit late on this, but I'd go with the screws (time saving) and you're not over-thinking it at all. There is an issue with the backer-board seating properly against the frame, but there are two types (maybe more). Use the type with the pan/rounded head (phillips drive) and it eliminates the problem.
    Dave My Pool Build, ODK Build
    22’X42’ Gunite Freeform 23K Gal, 10’X12’ Spa
    Diamond-Brite midnight blue, 1800sq. ft Kool Deck
    Pentair Easy-Touch 8, 2-2hp Pentair, 500lb Sand Filter, 400K btu Pentair heater
    Jun 2014
    Lake Jackson, Texas
    133
    Nope, you are not late, I haven't started yet. Thanks for the input! I'll take a look at those next time I'm at HD.
    Build - here.
    Killer95Stang's Avatar
    Sunny SoCal
    592
    I bought these self drilling 1/2" pan head zinc plated screws at a local lumber yard in a 5 pound box (about 500 screws) for about $14.00. These screws have a very flat wide head that makes them perfect for putting steel 20ga studs together. So far I'm about 3/4 of the way through my ODK frame build. I'll start a thread once I get to a point where I think I have something to show. Also, it takes a decent amount of time to place vise grip clamps on each stud connection, before installing the screws. I couldn't imagine having to clamp, drill, and then rivet. I'm a mechanical engineer. Forget all that point loading mumbo jumbo and start building your frame!!
    Pool done!! (backyard = work in progress) 32' x 19' inground freeform with 7' spa, baja step w/ (2) bubblers, stonescapes mini pebble finish, rock waterfall feature, 12" raised bond beam, Intelliflo VS, Whisperflo feature pump, (3) 5G Color LED's, FNS + DE 60, 400K Master Temp, Easytouch 8 w/ remote, Intellichlor IC40, Vision Classic Ceramic Kamado smoker, Margaritaville DM1000!!! Party Coming Soon!!
    TF-100 Test Kit w/ Speedstir
    Jan 2013
    Friendswood, TX
    320
    I used zinc coated self tapping screws and then sprayed each screw, front and back, with galvanized spray. I used the quick release plastic clamps from lowes I believe. It is a lot of work moving all the clamps around.
    Also, I built mine in the garage where it was flat. The patio wasn't quite perfectly flat. If your final area isn't flat built on site so you can match the contour and the counter is still flat. It took a lot to fix mine when I moved the frame around back.
    ~Paul
    19x40 IG including 10' BE, 18,000 gal, plaster, 48 SF DE, 1.5HP pump, AquaPure SWCG, Ozonejoe 30MR, Rockwaterfall, LED light, TF-100 Fill date 11/21/2014
    My ODK Build | My Pool Build | If You're From Texas Vote Here
