Results 1 to 11 of 11
Thread: Any electronically commutated (EC) AC booster pumps for pool skimmers available?
    Jun 2014
    CA
    38
    I find it surprising there are no drop-in EC AC motors to retrofit the thousands of pool skimmer pumps out there. Are there any options??
    Patrick_B's Avatar
    Jun 2011
    Midland TX
    14,998
    Re: Any electronically commutated (EC) AC booster pumps for pool skimmers available?
    I guess you mean the pool pump in general? And why do you find it so surprising?
    Essential Links:
    22,539
    Here you go.
    56 Frame ECM
    Jun 2014
    CA
    38
    I dorked up.. I meant ECM pool sweep booster pump..
    Jun 2014
    CA
    38
    Any electronically commutated (EC) AC booster pumps for pool sweeps available?
    For example, I have "Polaris" style booster pump that feeds my pool sweep. Are there any EC motors (variable speed in pool lingo) to retrofit onto my pool sweep pump section?
    mas985's Avatar
    Pleasanton, CA
    11,737
    I don't think they exist but I think it would be less costly and more energy efficient to just get a robot cleaner or even a non-booster cleaner (e.g. ThePoolCleaner).
    Mark
    Jun 2014
    CA
    38
    I think you are right. The only issue I see with the electric units is the "system integration" isn't what people are used to. What I mean is, you have a cord laying across the pool deck, versus the nice connection point to the water powered pool sweeps. It seems minor, but I think this comes into play. If there is a more efficient pump that just drops in, saves some power, and allows people to not "change" their habits/system, I would think the country could save some serious energy. Anyway, I'll take a look at the electric sweeps. They seem maintenance intensive and flimsy for the cost.
    n240sxguy's Avatar
    May 2014
    Benton, KY
    1,801
    Quote Originally Posted by robinasu View Post
    I can see your point with the cord from an aesthetic point, but how long is a cleaner gonna be running in the pool. If you are afraid someone will see your "unsightly" cord that powers your expensive robotic cleaner, then make sure it's not in there when company is over. If all of this is just for the cool factor of having a variable speed pressure side pool cleaner, I can't fault you for that. I think it's overkill, but I'm a fan of overkill. Where there's a will, there's a way. Im sure one could retrofit a variable speed motor onto a Polaris pump. I don't know the shaft sizes, but something could be made to work. Maybe pick whatever motor you like, and have a machine shop make an adapter.
    30K gallon IG vinyl. 1.5HP 2-speed Waterway Mustang pump. 600 lb sand filter. Polaris 280. Circupool SI-60+. TF-100
    mas985's Avatar
    Pleasanton, CA
    11,737
    Robinasu,
    I think you missed my comment about ThePoolCleaner. This particular cleaner does not require a booster pump but connects the same way as your existing cleaner and is used in the same way. It just doesn't need a booster pump which makes it very efficient.
    www.thepoolcleaner.com
    Mark
    Jun 2014
    CA
    38
    Ok, so it uses more efficient internal parts so it can run off the filter pump, only? Is that the deal? I'd like to take a look at it. Any dealers near Granite Bay, CA?
    mas985's Avatar
    Pleasanton, CA
    11,737
    Any pool store should carry it
    Just call around.
    Mark
