Thread: Intellichem FAIL=04H
    Jan 2015
    Flotida
    2
    HI,
    I have an Intellichem managing pH and ORP. There is an acid pump on the left and an Intellichlor connected. Firmware v 1.06. When the system starts-up in the morning I get a failure in Auto Calibration. Screen looks like this:
    AUTO CALIBRATION
    pH: 6.20 4.34
    ORP: 717 401
    FAIL=04H Press>
    After pressing > the next screen looks like:
    High PH X1:0349
    Low PH X2:0534
    High ORP X1:0717
    Low ORP X2:0401
    If I restart the system, it starts and operates normally. But for the last 5 mornings, every time it first starts, I get this error.
    Can anyone tell me what fail code 04H is and what might be causing it?
    Any help is appreciated.
    38,521
    Re: Intellichem FAIL=04H
    Welcome to TFP!!!
    How old is your system?
    A quick look at the Owners Manual indicates that 04H might be the "ORP too low error"
    TFP generally feels that the use of ORP sensors is not a good approach for outdoor residential pools due to the large fluctuations in the ORP value that can occur, especially when the stabilizer level (CYA) is maintained at the 70-80ppm we recommend for SWG pool. You might be much better off running your SWG in % output mode instead of relying on the ORP sensor.
    Jan 2015
    Flotida
    2
    Thanks Jason. The system is only a month old and had been running with no issues, until the last week. Just curious, I looked through the Installation and User's Guide for the IntelliChem and couldn't find the 04H error code. Where did you find it?
    Thanks!
    38,521
    It was in the troubleshooting area of the manual on page 50.
    Oddly, the Pentair site links to this which does not have the numbers: http://www.pentairpool.com/pdfs/IntelliChemOM.pdf
    But this version does have the numbers (found though Google search): http://www.pentairpool.com/pdfs/intellichemOM.pdf (lack of capital letters)
