Thread: SOLAXX vs CIRCUPOOL
    Jan 2015
    HUNTINGTON , NEW YORK
    4
    SOLAXX vs CIRCUPOOL
    I have a 38,000 gal. Gunite pool and live in new york , i am deciding which sw system to purchase , the solaxx produces 1.65 pounds per hour of chorine the circupool unit produces 2.1 , and offers a 60,000 gal. unit with a 7 year warrantee , on the surface the circupool seems to offer a better unit any help would be appeciated ,
    Patrick_B's Avatar
    Jun 2011
    Midland TX
    14,998
    Re: SOLAXX vs CIRCUPOOL
    Welcome to TFP Elliot.
    We usually suggest bigger than you need as in 1.5-2 x the rated size for your pool. As for Brands, I can't help, but others may chime in. Bigger is better no question.
    Essential Links:
    n240sxguy's Avatar
    May 2014
    Benton, KY
    1,801
    If it produces that much per hour, you're gonna need a bigger pool. I'd say the Solaxx is nowhere near big enough unless you want to run it 24/7 . I'm currently debating between a circupool and a pentair. My pool is about 34k gal. I'm torn between circupool which had quality issues with the previous model, and pentair which made my pool light that I despise. Those are the only ones I've found that produce more than 2lbs/day without going above $1000.
    30K gallon IG vinyl. 1.5HP 2-speed Waterway Mustang pump. 600 lb sand filter. Polaris 280. Circupool SI-60+. TF-100
    38,301
    As stated above, the chlorine ratings are per day and not per hour. And assuming running at 100% 24/7. With a 38k pool, I would recommend a 60k SWG system as a minimum size which should produce around 2.1 pounds per day or more.
    sargent's Avatar
    Aug 2013
    Tulsa, OK
    291
    I have a Circupool Si-40, and it works great. I have only had it one season, so I can't vouch for its longevity, but from what experience I have had I would not hesitate to recommend it.
    14k gal IG vinyl, Jandy Flopro 1 hp up-rated, 2 spd pump, Hayward 325 sq ft cartridge filter, Circupool Si-40 SWCG
