Results 1 to 15 of 15
Thread: Air bubles entering through pump inlet
    Oct 2014
    Bay Area, California
    146
    I can see air bubbles coming in through the pump inlet through the clear cover. I have inspected all the pipe joints that go to the pump and all seems well. The skimmer is clear/full
    there are constant small air bubbles coming out one of the jets.
    What next?
    Oct 2014
    146
    Re: Air bubles entering through pump inlet
    just saw in another post someone suggested running a garden hose over the piping, I will try that tomorrow but I listened carefully and couldn't hear any hissing through the piping
    If I find it to not be the piping then what next? Is it possible it could be underground? I don't know how air would get down there though.
    Jan 2013
    Friendswood, TX
    320
    Can you isolate your pump suction? Have it suck from only main drains or just skimmers? If so you could switch back and forth till the bubbles don't show up.
    ~Paul
    19x40 IG including 10' BE, 18,000 gal, plaster, 48 SF DE, 1.5HP pump, AquaPure SWCG, Ozonejoe 30MR, Rockwaterfall, LED light, TF-100 Fill date 11/21/2014
    My ODK Build | My Pool Build | If You're From Texas Vote Here
    Oct 2014
    Heartland
    14
    Having the same issue. Did the water hose check and found there where 2 o rings in my diverter valve in front of the pump and one was leaking. When i exposed the valve and started the pump it would not prime until i ran water over the oring and it primed right up once the air leak was filled. good luck!
    Oct 2014
    146
    There is no valve on the suction side, unless its underground. There is both a filter pump and pool sweep pump. Both lines go underground and probably meet I suppose.
    The pump primes great, this is a pretty small amount of air we are talking about here.
    Jan 2013
    Friendswood, TX
    320
    You wouldn't have valves underground.
    I assume you have main drains in the floor and skimmers. There isn't a valve to select one or the other?
    Does the air work it's way out or is it constant?
    I would try the water hose test.
    ~Paul
    Richard320's Avatar
    Jan 2010
    San Dimas, CA (LA County)
    19,034
    The most common problem is low water level or a stuck skimmer flapper causing a vortex in the skimmer. Take a look while it's running and see if there's a tornado in the skimmer well.
    Oct 2014
    146
    One pipe comes out of the ground and goes to the filter pump and one pipe comes out of the ground and goes to the sweep pump, or maybe goes from the sweep pump
    skimmer stays full
    Oct 2014
    146
    Success!!!!!
    Bubbles disappeared from the basket area completely with the garden hose. I feel a lot better know its not underground...
    Jan 2013
    Friendswood, TX
    320
    Where is the leak?
    ~Paul
    Oct 2014
    146
    Quote Originally Posted by Jabooh1 View Post
    Where is the leak?
    one of the inlet pipe connections
    Oct 2014
    146
    So it seems I have fixed the suction leak, but there are still some bubbles coming out one of the jets. I can't see any bubbles coming in the suction pipe through the inlet area
    Any ideas? there is a small leak in the filter (o-ring ordered), but that is pressure side so I don't think it could be that but I guess we'll see
    Jan 2013
    Friendswood, TX
    320
    If you had air leaking in for a while it might take some time to get it out of the system. Do you have the ability to bleed the filter off or any other high spots?
    Citizen's Avatar
    Oct 2014
    Orlando, FL
    92
    On what part of the pipe did you try the hose trick?
    Oct 2014
    146
    I did bleed the filter off, seal on it is really bad, new one on order. Hose trick was on inlet pipe.
