Thread: Nightmare Motor Repair!
    Nov 2013
    Fort Worth, TX
    114
    My waterfall pump was making noise and it was suppose to be a cold weekend here in Texas so I decided I'd replace the bearings in the motor. I have never done this before, but have the tools and watched several videos. I was able to remove the first 3 through bolts without any problems, but the last one finally broke when I applied some pressure to loosen it. I was able to get the motor apart and moved the piece to the garage where I sprayed it with some WD40. I tried removing the bolt with some vice grips and the bolt continued to break. I got down to about 3 inches of bolt left and soaked it with WD40 overnight. Today, I tried again and continued to break the bolt until I had only about 2 inches of bolt left. At that point I fired up the propane torch and heated the base for a few minutes. I was then able to see the bolt turn a little in both directions and did this several times. I could hear squeaking so I thought I had it. As I repositioned the vise grips and turned one last time, the bolt broke off just below the surface! I guess now I need to drill it out?
    Unsuccessful with the bolt, I decided to replace the bearings. However, I am unable to get the bearing out of the pump housing (I guess that is what it is). I have sprayed both sides of the bearing housing with WD40 and have beat the housing with a hammer to break it free of the bearing, but it will not move!
    Any idea how to get the housing off so I can replace the bearing?? Picture attached.
    30,000 plaster in-ground pool with spa; 2.5HP single speed Centurion pump; Raypak RP2100 propane heater; Polaris 280 with pump, waterfall with separate pump, Triton II commercial sand filter; TF-100 test kit w/ SpeedStir
    Divin Dave's Avatar
    Oct 2013
    Longview, Texas
    5,003
    Re: Nightmare Motor Repair!
    If the bearings are just stuck because of corrosion, you might try some PB Blaster. PB Blaster is the bomb! Walmart and auto parts store carries it. Wayyyy better for this type of thing than WD-40 ever thought about being.
    That's the best advice I can give you. Maybe someone else with more experience with this type of thing will chime in.
    Divin Dave,
    May 2009
    Youngsville NC
    395
    And if that doesn't work - you might consider simply replacing the motor with a new one. Be sure to get the same SFHP as your original motor.
    16x32 IG 19,000 gallons, Pentair 1.5 hp Energy Efficient Superflo pump (348024),vinyl liner, Chlorine dispenser, Hayward S-244T sand filter
    gtemkin's Avatar
    Jun 2008
    Seattle, WA
    738
    Any chance there's an internal circlip that is holding the bearing into the housing? You would look carefully at the outer diameter of the bearing and make sure there's no overhanging ring of steel blocking it's way out. If there is, that's a circlip and it would need to be removed first.
    21K gal 16' x 40' in-ground pool built 1959, old school with Jacuzzi bronze pump, American Products 24" Sand Filter & Americana Multiport valve, Jandy Lite2 millivolt heater, Coverstar cover, and classic Kreepy Krauly.
