Page 1 of 4 1234 LastLast
Results 1 to 20 of 68
Thread: Tulsa Pool Build, new IG
    TulsaKevin's Avatar
    Dec 2014
    Tulsa OK
    66
    Smile Tulsa Pool Build, new IG
    Just starting house construction a few days ago, started the pool building process. I have had two meetings with the PB, and we are still working out the details, but wanted to go ahead and post some pics and get yall's expert opinion to make sure that I am not missing anything obvious.
    GOALS: 1. To be large enough to host parties of occasional 20-50 people, with most likely weekly gathering of our youth group of 10-15 teenagers and mens group of about the same.
    2. To have a diving board/slide/jump area to be deep enough to be safe. Building ours closely to ANSI Type VIII standards.
    3. To have a diving board that actually works. , yes I know about the inherent dangers of diving boards. I know that driving is more dangerous as well as dietary choices on long term health.
    4. To have a "separate" shallow activity end that football, basketball, volleyball, and general pool fun can be have.
    5. Have a hot tub that can be used in hot tub weather, i.e. for me less than 40 degrees, the colder the better, and I want to be in the tub when it is so cold my hair freezes.
    6. Have efficient well maintained pool. TFP method will take care of this.
    7. Have a maximally long usage and comfort temp level of the pool
    Rough equipment: 2hp Ecostar Variable speed pumps, as well as several individualized pumps for water features, polaris 280 pool sweep with booster pump, 30 inch Highrate sand filter, 400k BTU NG heater, 125k BTU Heat chill pump, Interfab BYOS slide 21ft, Gemstone aggregate, Led lights, Gold line Salt system, Pl-4 automation system with wireless remote, Essex Grand Effects fire bowl, stamped stained salt concrete 2600ft, limestone grotto,
    Rough dimensions: Pool design 1 (130' perimeter, 3.6-9.6 ft deep, 45k gallon, 925 soft, 33x40ft)
    Pool design 2 (150' perimeter, 3.6 to 10 ft deep, approx 53k, approx 1100sqft, 33x49 deep to shallow with 20x37 shallow)
    Coming up with separate close able loop design for hot tub so the hot tub can be completely isolated from the pool and run to the heater, so we can keep the hot tub at above freeze guard temps and have it quickly heat. Heat/chill pump and NG to help extend swim season and comfort. Pump house will be a stand alone structure with the ability to have the temp maintain to above 40 degree and above. also it will serve as the chemical, toys, cleaning supply storage, outside shower and change area.
    TulsaKevin's Avatar
    Dec 2014
    Tulsa OK
    66
    Re: Tulsa Pool Build, new IG
    Cant seem to upload the second round of pics, only lets me add 250kb, when I go to try to post more, it won't let me delete the other files that I have added. I went to the manger and unselected all of the pictures, but does not "delete" them from my upload file.
    Nov 2014
    OH
    24
    Kevin,
    go to a place such as Photobucket, upload your pictures there, and then link back to TFP.
    TulsaKevin's Avatar
    Dec 2014
    Tulsa OK
    66
    sargent's Avatar
    Aug 2013
    Tulsa, OK
    291
    That will be a nice pool. For that size of pool you will probably want to have two SWG systems running in parallel.
    14k gal IG vinyl, Jandy Flopro 1 hp up-rated, 2 spd pump, Hayward 325 sq ft cartridge filter, Circupool Si-40 SWCG
    TulsaKevin's Avatar
    Dec 2014
    Tulsa OK
    66
    That is a great point, looked at the Hayward website and seems like the other than the Saline C 6.0, all others only work for up to 40k. I will talk to the PB and make sure the quote given for the salt system includes enough chlorine generator power.
    Thanks again.
    TulsaKevin's Avatar
    Dec 2014
    Tulsa OK
    66
    Finally got started, here are some early build pics. Like always, got to pick out tile, the tile I like is an upgrade, looked at possibility of stamped concrete, the stamp that I like is an.....upgrade, next time I build anything, which after building the house and this should be around never, but I am going to say I like something else then when they say upgrade, then I am going to choose what I really want. I going to get ride of the stamped concrete, just go with color and salted.
    Deep end looks real deep. We are going to have a diving board, so I wanted to go as deep as we could. IMG_20150731_164724832.jpg
    55,000 gallon freeform L-shape 40x50ft, 3'8-10', 150' perimeter, gunite, pebbletec (tbd), sand filter, 2hp Ecostar variable speed pump, 400k gas heater, Aquacomfort heat/chill pump, 8 jet spa with 2hp blower, limestone grotto waterfall, 20 ft BYOS slide with arch and water fall, grand effects wall torches and fire bowls, 1m diving platform with 14ft board, gold line salt system, full automation, stamp, stained and salted concrete
    bmoreswim's Avatar
    Jul 2012
    Central MD
    3,818
    Thanks for letting us join in on the ride. Is the pool house the wing of the house to the side or is there a separate structure not shown in the drawings. Maybe I missed something. What did you find out about the salt system size?
    Do you have a large built in trash/recycling station? You will be generating a bit of material with all of your gatherings. Nice to have an incorporated space for this task
    Can't wait to watch. How did the house build go? Or is it still going?
    18'x38' Rectangle (3'-8 1/2' deep w/ diving board) - 27K gal. w/ gray plaster
    Hayward equipment (cartridge filter, 2-speed pump, SWCG, automation) View Our Build
    Coverstar automatic pool cover | StoneMakers concrete retaining wall and decking | Merlin SmartMesh winter safety cover
    Spring 2013 Build | Dolphin Active 20 robot cleaner | Support TFP!
    Mod Squad kimkats's Avatar
    Jul 2012
    Tallahassee, FL
    30,497
    This is going to be a fun pool to watch!
    Okay is my job for you................
    Get a tape measure and measure everything as it happens! NOW is the time to make changes and fixes. Know that the steel will be ? inches off the ground (ask your PB) and your gunite will be about 3 inches thick.
    Make sure the walls are as far apart as they should be. Is the deep end deep enough? Is the tanning ledge how you want it?
    THANKS for sharing your build with us!
    Kim
    TulsaKevin's Avatar
    Dec 2014
    Tulsa OK
    66
    Going back in forth between two salt systems, they do make salt cells for commercial that are large enough, and surprisingly not very much more than residential. I guess they don't have all of the mark ups. The PB is talking to others to see what is the best, the advantage of two is that they replacements and parts are in stock and available, the commercial though only is one system so one is always easier to take care of than two. Should have an answer soon. As far as the materials, we are finishing up building our house at the same time, so we have a large dumpster. The rock, metal and reusables have been collected by the workers after they finish their projects. As far as dirt, we have a used it for landscaping. House should finish up sometime next month, the pool about the same. House went ok, most of the bids were accurate, but the bid for the concrete was way off because they initially thought the slope of the land was 3 ft, it was a little over 9 feet. I couldn't tell, and only after they poured the slab did it become apparent, but my complaint was, the contractor could have easily had it surveyed before the bid, or since they build a lot of houses, buy a gps surveyor equipment for himself and know exactly. We were going to pay for it anyways, because the slope of the land is the slope regardless, but it stings more when you have to pay for it out of the pocket all at once. Also, as usually, some of the bids for way to low, so we "upgraded" more than we thought. That being said, the granite was bid so low, that 3 of the 5 places that they recommended did not even carry anything that cheap.
    Be glad when it is all done and next year at this time, will be totally worth it, assuming we don't go into foreclosure before then
    The deep is 10ft plus, told him to fudge on the deeper side of ten, and we don't have a tanning ledge. Personally I wanted to maximize every square inch for playing, that is why I decided on a L shape, so you have a shallow end for all of the water games, but a deep end for the slide and diving board. Also I added a standing ledge on the deep end so you can be in the deep end and still throw a ball or frisbee to the shallow end or just hang out. It will be in the corner between the slide and the diving board.
    bmoreswim's Avatar
    Jul 2012
    Central MD
    3,818
    Quote Originally Posted by TulsaKevin View Post
    Great decision on the standing ledge. We have two and they are the best feature of our pool. On the salt cells, the two residential a might be a good idea in that if one fails the other one will be able to handle much of your chlorination needs with some bleach additions. I think the manufacturers pad their ratings a bit on what they can do.
    Thanks for the house details. They are fun to hear. Sounds like you have a good attitude about it.
    Aug 2014
    Houston tx
    2,524
    That is one ginormous pool! Definitely will be fun to watch.
    Marla
    No longer living vicariously through other people's pool builds. Pool build is complete on my IG SWCG pool, approx 10,000 gallons. All Jandy equipment - VS 1.5 hp pump, 580 cartridge filter, AquaPure 1400 salt cell, AquaLink PDA system. Dolphin m500. PebbleSheen Blue Surf with shells and beads added. TF-100 w/ SpeedStir. A Houston Pool Build Inside the Loop
    TulsaKevin's Avatar
    Dec 2014
    Tulsa OK
    66
    PB was here at 545am, started the water running around 6 am, pumped and worked till 630pm. Question. The air temp is a very pleasant 84 degrees, the sun has set, the nights low is around 75. Do I need to water, text the PB, haven't heard back, tomorrow I assume that they will be back, weather is a only supposed to be around 90 tomorrow. Saturday was 102 with humidity near 65%, so this has a been a tremendous relief.
    Do I need to water, looks fine to me.
    Jul 2015
    Yukon/OK
    41
    I absolutely love this pool! It is HUGE and going to be so much fun!
    JamieP's Avatar
    May 2011
    Waxahachie, TX (south of Dallas)
    1,135
    This is the big granddaddy version of the pool we are trying to build. The one we are working on is closer to your first design, but with a prefab slide and no spa. Yours is going to be awesome for you! We love the idea of an L shaped pool for all the reasons you mentioned. Unfortunately, since we are digging into solid limestone, we won't be digging as deep because of cost, but it is great that you can. I'll be looking forward to following your build. Thanks for sharing!
    28,000 gallon freeform, Stonescapes Tropics Blue Minipebble with abalone, 3.5' to 8.5' depth. 2 skimmers, 5 returns, dedicated vacuum port, Dolphin Z5 robot. All Pentair equip: EasyTouch 8, IC60 SWG, VS pump, 520 Cartridge Filter, 3 Intellibrites, 2 Color Cascade Bubblers. TurboTwister Slide and 8' Salt System Jump Board. TF-100. My Jan-Mar 2016 build:
    Waxahachie, TX Owner Build - A race to beat the baby!!
    Jul 2012
    Tallahassee, FL
    30,497
    You do need to water as much as possible. The watering is not so much temperature related as it is curing. You do it to prevent it from cracking.
    Kim
    JamieP's Avatar
    May 2011
    1,135
    What is the depth of your shallow end? Did you choose to keep it at one consistent depth (which is how it looks to me in your photos)?
    TulsaKevin's Avatar
    Dec 2014
    Tulsa OK
    66
    It is from 3'6 to 4 ish, there is a little slope to it, PB made it slope, I did not have a strong opinion about it. Since the spa and grotto are were it starts sloping, and we have a lot of monkeys that live here, figure someone is going to jump off anyway near the shallow end. The grotto slopes off to 7 foot on the other side. The slide is right at 9 feet.
    JamieP's Avatar
    May 2011
    1,135
    I was just thinking about your pool today. Any updates?
  20. Back To Top    #20
    TulsaKevin's Avatar
    Dec 2014
    Tulsa OK
    66
    Have some pipe.
    I see all of this and get real nervous after reading several people who have developed a pool leak, that is a lot of joints and couplers.
    Doing the leak test as we speak. They started on Thursday and worked from 8 tip 6pm this Saturday. IMG_20150828_185115601.jpgIMG_20150828_185357802.jpg
