Results 1 to 8 of 8
Thread: Which Test Kit ??
    Oct 2014
    South Florida
    14
    Which Test Kit ??
    currently using a taylor k1000 for FC and PH.
    TA, CH and CYA are tested at the local pool shop.
    need new kit for testing FC beyond 5.
    Richard320's Avatar
    Jan 2010
    San Dimas, CA (LA County)
    18,967
    Re: Which Test Kit ??
    Best bang for the buck is the TF100. Same reagents as the Taylor K-2006, but the quantities are more realistic.
    http://tftestkits.net/TF-100-Test-Kit-p4.html
    If you ever planned to become a TFP supporter, you'll get a discount on the test kit if you sign up first.
    I recommend the speedstir as well - it really improves the testing. And if you spring for the XL option now, you will save on shipping when you need refills. The FAS-DPD powder is very difficult to find in stores; the other reagents are easy to get if you get caught short somehow.
    Mod Squad tim5055's Avatar
    May 2014
    Franklin, NC
    9,184
    Quote Originally Posted by UaVaj View Post
    Richard has already covered which kit you should get, so I'll skip that.
    Sorry to disagree, but you need a new kit to test more than FC above 5. If you have read around here much you have probably seen that not much credence is given to pool store testing. While you would think that a "professional" would be the best, unfortunately in most cases it is quite the opposite. Between employees who blindly trust the word of chemical sales representatives and high school kids working in the pool store for the summer you end up with poor results from their testing. Two different pool stores told me my CYA was in the 80 - 100 range, but when I tested myself I found it 200+. Just for laughs I took three samples, tested one myself and took the other two to two different stores. While some of their numbers were close to mine, others were off the chart. Test everything yourself.
    Support the site
    Nov 2014
    OH
    24
    This.
    Patrick_B's Avatar
    Jun 2011
    Midland TX
    14,998
    The TF 100 is the best buy for sure. If your pool is doing ok right now, it will go on sale in March.
    Essential Links:
    Mod Squad JVTrain's Avatar
    Feb 2014
    Central Minnesota
    5,080
    Another super thumbs up for the TF-100. Best value and when ordering reagents for refills, they ship quick. Fresh reagents as well. http://tftestkits.net/ is great to work with.
    +1 Speed Stir as well. Some view it as a toy/unnecessary but I really think it helps with mixing thoroughly and consistently.
    Isolated Spa - 345 Gallons
    jrs_diesel's Avatar
    Aug 2014
    League City, TX
    215
    I got a TF-100 last year, quite happy with it.
    Highly recommend the Speed-Stir as well. Really helps keep the testing consistent.
    J.R.
    20K IG gunnite pool
    2HP Hayward single speed pump
    Cartridge filter
    Patrick_B's Avatar
    Jun 2011
    Midland TX
    14,998
    Quote Originally Posted by jrs_diesel View Post
    I agree on this point for sure. The SS will really make testing a lot easier. It's worth every penny.
    Essential Links:
