Results 1 to 20 of 20
Thread: Fly-by-Wire Grilling
    BoDarville's Avatar
    Jun 2012
    DFW, Texas
    3,841
    http://www.lynxgrills.com/smart-grill.asp
    The very latest in grilling technology. Yes, it's cool but it kinda takes something away from the grilling experience IMHO. I still want to have some control of the grilling process and an excuse to have cold beers while tending the hot grill. I'll stick with my Thermapen as the only electronic aide I use while grilling.
    Jan 2013
    Friendswood, TX
    320
    Re: Fly-by-Wire Grilling
    Interesting. I'll wait for the version that generates food from thin air.
    "Smart Grill. Ribeye medium rare"
    ~Paul
    19x40 IG including 10' BE, 18,000 gal, plaster, 48 SF DE, 1.5HP pump, AquaPure SWCG, Ozonejoe 30MR, Rockwaterfall, LED light, TF-100 Fill date 11/21/2014
    My ODK Build | My Pool Build | If You're From Texas Vote Here
    MARCO...polo's Avatar
    Oct 2014
    East Contra Costa County CA
    102
    Tech analyst for CBS, Larry Magid, does a brief daily afternoon segment on the local radio affiliate. He was talking about either this grill or a similar 'connected grill' yesterday. If memory serves me true, the price he stated was $6 to $8 THOUSAND!!!!
    13,000 gal.Peanut shaped IG Plaster (med. gray) w/ 7' raised spa. ALL Pentair: Intelliflow 3hp VS, Cartridge filter, 400,000 btu heater, 2.0hp spa motor, Easy Touch control panel & is4 spa side switch, Intellichlor 40C SWG, Paramount PV3 In Floor cleaning system, spa spillway and two sheer descents. Solar: 10 FAFCO panels 1.5hp booster. Testt kits: K-2006 & K1766 (Chloride/Salt) Fill date August 15, 2114.
    Richard320's Avatar
    Jan 2010
    San Dimas, CA (LA County)
    18,967
    I'm such a Luddite. I still use a charcoal grill.
    Jan 2013
    Friendswood, TX
    320
    I looked it up. 6$k for 30" I believe.
    ~Paul
    Administrator Leebo's Avatar
    Jul 2011
    Eastern Ohio
    7,075
    I'd love it just for the ability to turn it on and off from inside. Going outside in 10 degree weather to preheat the grill stinks.
    http://www.consumerreports.org/cro/n...ands/index.htm
    BoDarville's Avatar
    Jun 2012
    DFW, Texas
    3,841
    Quote Originally Posted by Richard320
    I hear ya Richard. While I do have gas grills, I also have a dedicated offset wood-burning smoker (a.k.a., stick burner) that I use primarily for briskets, pulled pork, and ribs. The main section (big drum) can also be used as a charcoal grill. Yes, it's a bit of effort, but again- provides more excuses for those cold beers
    Jan 2013
    Friendswood, TX
    320
    Agreed. I have a 32" gas grill who's main job is to hold extra grates for my primo oval XL.
    ~Paul
    Melt In The Sun's Avatar
    Oct 2009
    3,899
    Yep, my charcoal grill (big steel keg) is for when I'm feeling lazy. The stick burner just makes everything better!
    I have a hard time believing that auto-cooking thingimajig will work well.
    Patrick_B's Avatar
    Jun 2011
    Midland TX
    14,998
    Quote Originally Posted by Leebo View Post
    I'd love it just for the abality to turn it on and off from inside. Going outside in 10 degree weather to preheat the grill stinks.
    Did you know this isn't the best kind of weather for Grilling Leebo?
    Essential Links:
    Mod Squad JVTrain's Avatar
    Feb 2014
    Central Minnesota
    5,080
    Had a gas grill for years, then got rid of it during my last move. Charcoal ever since and love it.
    I'll try a Primo some day...
    Isolated Spa - 345 Gallons
    Mod Squad woodyp's Avatar
    Apr 2010
    East Texas
    9,569
    NOTE TO BO: I think you'd be better off with a "smart fridge" rather than a smart grill to keep your beer cold!
    BoDarville's Avatar
    Jun 2012
    DFW, Texas
    3,841
    Quote Originally Posted by woodyp
    Now your talkin'!
    JayBauman's Avatar
    Sep 2014
    Katy, TX
    617
    I'm a high-tech kinda guy, and I too use charcoal grill.
    A few moves ago, we found ourselves without a big ol' grill and didn't want to purchase one until the outdoor kitchen went in. I bought a cheap charcoal grill. Fast forward 4 years, and I'm still using charcoal...albeit I've upgraded to a Weber kettle. Charcoal makes food taste so much better, I cannot imagine going back.
    23' x 37' IG 18.5k gallon SWG w/ raised spa, Build Thread -->Here
    Wet Edge® Pearl Matrix®, Hayward® SwimClear™ 525 ft², Hayward® Goldline Controls® PS-8
    4x Hayward® TriStar™ pumps, Paramount PCC2000® ICS, TF-100 w/Speedstir
    Apr 2010
    East Texas
    9,569
    I cheated and the last grill I bought is a combo gas/charcoal grill.
    pwrstrk's Avatar
    Elverson Pa.
    4,758
    Quote Originally Posted by JayBauman View Post
    A few moves ago, we found ourselves without a big ol' grill and didn't want to purchase one until the outdoor kitchen went in. I bought a cheap charcoal grill. Fast forward 4 years, and I'm still using charcoal...albeit I've upgraded to a Weber kettle. Charcoal makes food tast so much better, I cannot imagine going back.
    Jay, I also have a Weber kettle grill and wouldn't be without it. I've had it for 12 years now. Hard to find a better charcoal grill IMO.
    Jeff
    Mod Squad pooldv's Avatar
    DFW, TX
    24,450
    Love our primo XL and cyberQ wifi. Best of both worlds!
    BoDarville's Avatar
    Jun 2012
    DFW, Texas
    3,841
    Quote Originally Posted by Jabooh1
    With current high beef prices, this would indeed be nice.
    Apr 2010
    East Texas
    9,569
    I'm down to bologna~!
  20. Back To Top    #20
    DFW, TX
    24,450
    Quote Originally Posted by woodyp View Post
    Grilled or smoked?
