Thread: What is this? Is it a problem?
    Nov 2013
    Fort Worth, TX
    114
    I'm in the process of rebuilding my Centurion Pac Fab motor with new bearings and a new seal. I have started to take the motor apart and found this part in the pump. I'm not sure what it is, but the green ring (seal?) on the inside is falling apart. Is this a problem? Can I replace just the seal or do I have to buy the whole part?
    30,000 plaster in-ground pool with spa; 2.5HP single speed Centurion pump; Raypak RP2100 propane heater; Polaris 280 with pump, waterfall with separate pump, Triton II commercial sand filter; TF-100 test kit w/ SpeedStir
    Nov 2013
    Fort Worth, TX
    114
    Re: What is this? Is it a problem?
    Found out it is a diffuser. Costs about $25 on line. I'm not sure how important the green ring is?
    38,271
    If it is in the pump and falling apart ... It is likely pretty important to replace it while you have the pump apart.
    Richard320's Avatar
    Jan 2010
    San Dimas, CA (LA County)
    18,984
    I'll just share the answer I use when people ask me if a particular part is necessary on their car: If the manufacturer could leave it out and save a few cents per car, they would.
    Nov 2013
    Fort Worth, TX
    114
    Part is now on order....thanks!
