Thread: What is the best way to heat 32,000 gal gunite pool?
    We are getting ready to move into a home that has a pool that is not heated. Would love to hear opinions on what's the best and most cost efficient way to heat the pool. Electric, solar, gas, off the a/c? We live in New Jersey and will need to heat the pool mostly in May (when we open) and in September.
    Scott From Florida
    Re: What is the best way to heat 32,000 gal gunite pool?
    If you have somewhere to put solar panels, they are by far the least expensive option. Gas heat is good for "event" heating, i.e. heating for that one perfect early spring weekend. Heat pumps are best if you want to keep the pool heated for weeks at a time.
    One thing to keep in mind, other than solar, heating the pool tends to be wildly expensive.
    BoDarville's Avatar
    Jun 2012
    DFW, Texas
    3,841
    Jason's given you good advice on the heating options.
    As an example of how expensive it is to heat a pool that size, the teenage kids of someone I used to work with had a pool party. After the party, they left the gas heater (as well as the pump) on for several days (forget the exact # of days but it was less than a week). Their gas bill went up a few hundred $ from what it normally should be for that time of year. Mom was not too happy.
    I only use my heater to heat the pool in the spring when Mother Nature is working with me but, even then, I run it for only 2-4 hours at a time. I avoid using it in the fall since it is a losing battle. OTOH, I'll use it to heat the spa whenever we feel like using it but we are only talking about 800 gallons there.
    Pool Clown's Avatar
    Sep 2008
    Silicon Valley, CA
    1,691
    Start with a solar cover. See how well it does in the spring. If is does well, problem solved for under 200 dollars. If it doesn't perform as expected, then consider the solar or gas heater.
    Factory Warranty Station for:
    pwrstrk's Avatar
    Elverson Pa.
    4,758
    Whatever heating option you decide on I would invest in a solar cover. The cover will help a lot in retaining heat that you would lose over night due to evaporation. A solar cover will help somewhat in heating the water but their best at retaining heat. Due a search on the forum for solar covers. Lots of threads on the subject.
    Here's a good place to purchase Solar Covers
    Jeff
    pragmatic's Avatar
    Jul 2011
    Friendswood, TX
    521
    For the occasional winter /spring swim, NG has my vote. Here's a good reference post I made awhile back http://www.troublefreepool.com/threa...hlight=heating
    Dave My Pool Build, ODK Build
    22X42 Gunite Freeform 23K Gal, 10X12 Spa
    Diamond-Brite midnight blue, 1800sq. ft Kool Deck
    Pentair Easy-Touch 8, 2-2hp Pentair, 500lb Sand Filter, 400K btu Pentair heater
