Results 1 to 10 of 10
Thread: How much concrete do you have?
    Dec 2014
    Saugus
    8
    Hi All,
    New to this forum and about to partake on my second pool build.
    I have a question on the amount of concrete/patio space you all have used for your pools.
    I'm thinking a 3-4 foot apron on 3 sides and then bringing the patio back about 15' to have space for table/chairs/grill etc..
    So I guess my question is how many sf of deck do you have? 400,500,1000sf?
    Any pictures illustrating the approximate square footage of your decks would be extremely helpful.
    Thank you in advance.
    Mod Squad JohnT's Avatar
    SW Indiana
    9,199
    Re: How much concrete do you have?
    I have 3ft on the back side of the pool, about 6ft on the end with the diving board, and 12ft on the side where we sit. If I were doing it again I'd go 4ft on the back side. 3ft is much narrower than it sounds.
    Jan 2013
    Friendswood, TX
    320
    I have about 1,360 sqft.
    960 open
    400 covered
    ~Paul
    19x40 IG including 10' BE, 18,000 gal, plaster, 48 SF DE, 1.5HP pump, AquaPure SWCG, Ozonejoe 30MR, Rockwaterfall, LED light, TF-100 Fill date 11/21/2014
    My ODK Build | My Pool Build | If You're From Texas Vote Here
    Apr 2014
    Huntsville Al
    11
    We have 4 ft on the back side, 5 ft one end, 12 ft other end, 15 ft on the patio side near the house. The pool is 18 x 36.
    Attachment 34063
    Attachment 34062
    22k gal, 18 x 36 IG vinyl, Pentair 320 cartridge filter, 3/4 HP 2 spd WhisperFlo pump, Intermatic P1353 timer, Dolphin Nautilus Plus
    Divin Dave's Avatar
    Oct 2013
    Longview, Texas
    5,005
    Pool size in my sig.
    the apron around the pool is 4 ft. 3 is much narrow that it seems. 4 seems to be just right.
    The big part is 26 x 16 (not the best pic, but the only one I have access to at the moment)
    Divin Dave,
    bmoreswim's Avatar
    Jul 2012
    Central MD
    3,822
    I do agree that 4' seems to feel about right if you can do that as the skinniest measurement. We have that on the far side. Our others are about 10' & 15' on the ends and 13' on the side. This is pretty big (1,650 S.F.) but our yard is wide open and the pool is a destination pool so there is no adjacent space to use. The house deck and patio areas are separate. At least 12' gives you plenty of play/walking/socializing space between chaise lounges laid down flat and the pool even with people sitting with legs a dangling in the pool.
    18'x38' Rectangle (3'-8 1/2' deep w/ diving board) - 27K gal. w/ gray plaster
    Hayward equipment (cartridge filter, 2-speed pump, SWCG, automation) View Our Build
    Coverstar automatic pool cover | StoneMakers concrete retaining wall and decking | Merlin SmartMesh winter safety cover
    Spring 2013 Build | Dolphin Active 20 robot cleaner | Support TFP!
    Nov 2014
    North Texas
    16
    We have around 560 sq ft. on a 32X17 pool. Everyone we asked for suggestions all said get as much deck as you can afford. I was very specific about wanting several areas/groupings for entertaining.
    17K freeform, IG, Primera Stone Sky Blue Treasure, Pentair DE, Intelliflo VS+SVRS, NOV 2014, K-2006, Pentair Racer, no gas in our area so pool only, no heater, will be looking at adding solar next season
    Jun 2011
    Carlsbad, NM
    172
    We have right around 2000 sf of deck. 600 sf is covered.
    36' x 18' 20k in ground, Finest Finish grey plaster, Pentair Tagelus 100D sand filter, Hayward Northstar 2hp pump, Jandy LRZ125EN heater, spill over spa, iaqualink controlled automation, Stenner chlorination, natural rock and flagstone coping, 1" glass mosaic waterline tile, SR Smith Vortex slide.
    Dr. Hops's Avatar
    Feb 2015
    Canton, GA
    31
    We have just shy of 1000 square feet. 4 feet on the long edges and around 16 feet by 20 feet on the sides.
    Dr. Hops's Avatar
    Feb 2015
    Canton, GA
    31
