Page 1 of 2 12 LastLast
Results 1 to 20 of 28
Thread: Brrrrrrrr.....
    MermaidMama's Avatar
    Aug 2013
    Pennsylvania
    158
    Brrrrrrrr.....
    This frigid cold up north has me daydreaming about my pool! Man, I'm hoping that groundhog don't see his shadow. Ha!
    MermaidMama
    18' Round x 52" Doughboy AGP ~ TF-100 Test Kit
    Powerline XP Pump 1.5 HP ~ AquaView 20" Sand Filter ~
    Divin Dave's Avatar
    Oct 2013
    Longview, Texas
    5,027
    Re: Brrrrrrrr.....
    Brrrrr is right!!
    Divin Dave,
    pwrstrk's Avatar
    Elverson Pa.
    4,758
    Re: Brrrrrrrr.....
    It's cold here also !!
    Jeff
    Aug 2014
    Northern IL
    4,615
    Re: Brrrrrrrr.....
    TFSR Trouble Free Skating Rink
    smforte's Avatar
    Sep 2013
    Montgomery,Al
    668
    Re: Brrrrrrrr.....
    Freezing in Bama too....dreaming of flip flops, pool floats and piņa coladas
    Montgomery, AL
    27000 16 x 36 IG, Vinyl, Grecian, Hayward Sand filter, 1 HP Pentair whisperflo motor, Aqua Genie filter not by choice, no extra jets, Dolphin s300i robotic cleaner,Taylor K 2006 test kit, speed-stir which I couldn't live without!
    BoDarville's Avatar
    Jun 2012
    DFW, Texas
    3,841
    Re: Brrrrrrrr.....
    Below freezing the past few nights in DFW also. High temps are forecast to be in the 40's for much of the next week but still flirt with the freezing mark at night. At least no ice on the roads for now.
    wjr75's Avatar
    Jun 2013
    IL
    836
    Re: Brrrrrrrr.....
    Only getting to -9 deg below zero tonight in Chicago......What????
    Inground 22k gallon gunite 15x31 main pool, 15x7 wading pool/sunning deck, hot tub/with overflow (9' octagon with limestone top) & slide NSWG, Aqua Blue Pebble Sheen
    Filter dual cartridge Sta-rite 450sq/ft, TF-100 Test Kit
    Heater Raypak 2100 400k btu cupro-nickel exchanger
    Auto pool cover, Polaris 280 auto pool cleaner, Jandy AqualinkRS8 Remote Control System
    Aug 2014
    Northern IL
    4,615
    Re: Brrrrrrrr.....
    And the wind chill is brutal here in Chicago area too. Way, way too cold for the dog to even want to do her business!!!
    northrn's Avatar
    May 2014
    Cincinnati, OH
    532
    Re: Brrrrrrrr.....
    A balmy 10 degrees tonight in Ohio.....curled up with a good book and daydreaming my life away....
    27' AG 18K Gallons ~ Cartridge Filter ~ Pentair 1.5 HP Pump
    Aug 2014
    Northern IL
    4,615
    Re: Brrrrrrrr.....
    Daydreaming of company around the pool, beer, fire maybe, stars... I getcha!
    TSiGirl's Avatar
    Mar 2013
    Crystal Lake Illinois
    514
    Re: Brrrrrrrr.....
    Daydreaming is right..they closed schools down here for 2 days(wind chills in -30 range or so).
    Cornelius 15 Round , Semi Inground, TF-100 Test Kit, Speedstir,
    Hayward 2 Speed Pump Swimpro 150 Cartridge Filter,Intermatic Timer, Hardplumbed,
    Pool Rover S2-50, 2 Maytronics Solara Heating System Panels.
    Aug 2014
    Northern IL
    4,615
    Re: Brrrrrrrr.....
    3 days in Elgin!
    PAGirl's Avatar
    Jun 2012
    Central PA
    2,388
    Re: Brrrrrrrr.....
    -5 forecasted here in central PA tonight. But at least we had a pretty sunset! (Though I froze taking the picture, it was around 7 degrees when I took it)
    EVChargeGuy's Avatar
    Jun 2014
    Long Island, NY
    340
    Re: Brrrrrrrr.....
    It's 13 degrees now but we're getting a heat wave that should bring the temp above freezing today, maybe some of the snow will melt
    IG Tear Drop, Dark Gray Gunite , 27,000 gallons -Age 50+-years, very old Hayward Split Egg Sand Filter with side mount Multi-port- Hayward SP2600VSP Pump- Hayward chlorine feed (not used since finding TFP) - Laars 315K BTU Oil heater- LoopLoc Safety cover- AquaBot RAPIDS 4WD- TF-100 Test Kit w/ Speedstir- 390 Gal Hot Springs Spa Envoy installed May 2017
    Patrick_B's Avatar
    Jun 2011
    Midland TX
    14,998
    Re: Brrrrrrrr.....
    I can't stand winter! I think we're all I good company around here. Pool people are summer people!
    Counting them down....
    Essential Links:
    TSiGirl's Avatar
    Mar 2013
    514
    Re: Brrrrrrrr.....
    Quote Originally Posted by Brushpup View Post
    I totally agree...hate winter and I'm counting down till pool opening time.
    Re: Brrrrrrrr.....
    Above freezing for a few days but I still have a 13,500 gallon ice cube (don't ask for the weight) - at least I'm not worrying (yet) about water chemistry!
    24 foot AG Vinyl, 10 year old wall, 1 year old liner
    Hayward 240T Sand (free!)
    Hayward 1.5 hp pump (free)
    BBB just ROCKS!
    Divin Dave's Avatar
    Oct 2013
    Longview, Texas
    5,027
    Re: Brrrrrrrr.....
    Captains Log. Tuesday, January 19, 2015.
    Planet Earth - located in the Orion Arm of the galaxy Milky Way.
    The last 3 days have been absolutely gorgeous weather in North East Texas. 67 and Sunny with a hint of springtime on the breeze. So pretty in fact, that I played hookie from work! The pool is clean and gorgeous and the bottom of my pool is shimmering with sunligt to the degree that sunglasses are a necessity, lest a retina burn is suffered! Love me some sunny weather and TFP!
    Divin Dave,
    Casey's Avatar
    SW PA
    10,461
    Re: Brrrrrrrr.....
    I'm ready for Spring to get here.... It's been cold. I work outside at night and I'm over this winter already. I was cutting peppers today thinking of gardening... That's how much I miss the warm weather!
  20. Back To Top    #20
    May 2014
    Clarksburg, WV
    331
    Re: Brrrrrrrr.....
    Quote Originally Posted by MermaidMama View Post
    He saw his shadow!!!!! You Jinxed us!!!!!
    24'x54" 15k AG round - Outback Genesis
    1 1/2hp Hayward Matrix 2 speed. Hayward 180T Sand Filter
    TF-100 Test Kit
    Pool School & TF-100
    How to SLAM
