Page 1 of 2 12 LastLast
Results 1 to 20 of 22
Thread: Cost to run pump for freeze protection
    mas985's Avatar
    Pleasanton, CA
    11,743
    How do you get to $.40? A 1.5 HP Jandy pump uses about 2.2 kw per hour so how much do you pay per kwh? Even at $0.05 / kwh, that is $0.88 for 8 hours of run time.
    Mark
    Jan 2013
    Friendswood, TX
    320
    Re: How to manage pool during freezes
    I guess the biggest thing is that we are not below 32* for eight hours in Houston.
    Kw=(motor hp)*(efficiency)*(power factor)
    For a typical 1.5hp pump the efficiency is 0.78 and power factor is 0.81.
    I pay $0.08/kW.
    So $0.46=(1.4kw)*($0.08/kW)*(4 hours)
    I only run it when it's 32* or below.
    I am using typical motor data as I have clamped an amp meter on my new pump yet.
    ~Paul
    19x40 IG including 10' BE, 18,000 gal, plaster, 48 SF DE, 1.5HP pump, AquaPure SWCG, Ozonejoe 30MR, Rockwaterfall, LED light, TF-100 Fill date 11/21/2014
    My ODK Build | My Pool Build | If You're From Texas Vote Here
    mas985's Avatar
    Pleasanton, CA
    11,743
    No, that is not the correct equation.
    First, based upon actual measurements, the power draw for a typical 1.5 HP pump is 2.2 kw not 1.4 kw.
    Second power factor is only used when calculating power with RMS volts times amps so it should not be used in the equation you showed.
    Third, you should divide by efficiency to get power draw, not multiply.
    The correct equation is:
    Electrical Power (kw) = Label HP * Service Factor / Motor Efficiency * 0.7457 kw / HP
    1.5 HP * 1.65 SF / 0.78 * 0.7457 = 2.37 kw
    But that is at service factor load. Nearly all pump motors run below full load which is why the measurement shows 2.2 kw.
    Mark
    Jan 2013
    Friendswood, TX
    320
    How do you derive your service factor of 1.65?
    ~Paul
    mas985's Avatar
    Pleasanton, CA
    11,743
    It is not derived but a rating that is listed on the motor label. A typical 1.5 HP full rated pump has as a motor service factor of 1.65. An up rated pump is around 1.1.
    BTW, if you tell me which pump model you have, I can tell you more accurately what the power draw actually is from APSP measurement data.
    Mark
    Jan 2013
    Friendswood, TX
    320
    So using your number, 4 hours, $0.08/kW it's $0.70.
    ~Paul
    mas985's Avatar
    Pleasanton, CA
    11,743
    So do you manually turn off your pump after 4 hours or have automatic freeze protection?
    Mark
    Jan 2013
    Friendswood, TX
    320
    I have been checking the weather each night and looking at when it is 32* or less. The last few times it I have only had the pump on from 1am to 5am.
    ~Paul
    n240sxguy's Avatar
    May 2014
    Benton, KY
    1,801
    Re: Cost to run pump for freeze protection
    I don't know about freeze protection, but a little math like previously mentioned will get you in the ballpark. My pump costs almost $.21 per hour that it runs. That's around $5 a day if it ran 24 hours a day, which it did when I bought it.
    30K gallon IG vinyl. 1.5HP 2-speed Waterway Mustang pump. 600 lb sand filter. Polaris 280. Circupool SI-60+. TF-100
    Jan 2013
    Friendswood, TX
    320
    What is your electric rate?
    ~Paul
    n240sxguy's Avatar
    May 2014
    Benton, KY
    1,801
    $.10078/kWh
    Richard320's Avatar
    Jan 2010
    San Dimas, CA (LA County)
    19,075
    Whatever it costs, it's going to be less than a new pump housing.
    n240sxguy's Avatar
    May 2014
    Benton, KY
    1,801
    That's very true
    mas985's Avatar
    Pleasanton, CA
    11,743
    A pump housing has far more volume per surface area than the piping so will take much longer to freeze and much less likely to freeze. A 5" diameter pump basket in a 15 MPH wind will take over 50 hours to freeze at an average temperature of 25F and 30 hours at an average temperature of 20F. A 2" pipe will freeze in half that time.
    Mark
    Richard320's Avatar
    Jan 2010
    19,075
    Quote Originally Posted by mas985 View Post
    I stand corrected.
    Let me rephrase that: Whatever it costs to run the pump overnight, it's going to be less than the cost of the PVC fittings to repair a broken pipe.
    Killer95Stang's Avatar
    Sunny SoCal
    592
    Seems a like such a hassle to have actual weather....
    Pool done!! (backyard = work in progress) 32' x 19' inground freeform with 7' spa, baja step w/ (2) bubblers, stonescapes mini pebble finish, rock waterfall feature, 12" raised bond beam, Intelliflo VS, Whisperflo feature pump, (3) 5G Color LED's, FNS + DE 60, 400K Master Temp, Easytouch 8 w/ remote, Intellichlor IC40, Vision Classic Ceramic Kamado smoker, Margaritaville DM1000!!! Party Coming Soon!!
    TF-100 Test Kit w/ Speedstir
    mas985's Avatar
    Pleasanton, CA
    11,743
    Risk assessment isn't just about a single event or a single night of running a pump. It is about the probability of the event occurring vs the recurring cost of risk mitigation. So if you turn on your pump every time it gets below 32F even though there is zero probability of a freeze event occurring, that is simply a waste of money without any benefit. As temperatures drop and/or duration of time below 32F lengthen, the probability of freezing increases so the benefit of running the pump might increase. However, not every freeze event results in a damage event either.
    For example, if the probability of freezing when temperatures drop below 32F is 10% and the probability of damage is 10% of that, the probability of damage is only 1% of the below 32F events. So 1 out of 100 days there is damage. If it costs $1 per night of running the pump, the actual cost of the insurance is $100, not $1. But in many cases, the probability is far less than that even when temperature get down to the low teens which means the cost of the insurance is much higher.
    In 2012 we got down to 13F and there was no damage to my equipment even without running the pump. But I knew ahead of time there wouldn't be any freezing of my equipment. Time to freeze was 14 hours under those conditions, and we never have freezing temps longer than about 6 hours.
    All I am suggesting is that it can be an waste of money to blindly run the pump the moment temperatures drop below freezing. With little effort, you can reserve running the pump for those conditions where there is actually a probability of freezing. At that point, it might make sense although the probability of damage is still fairly low.
    Mark
    Jan 2013
    Friendswood, TX
    320
    True, but I sleep better.
    If it's 1:100 then I don't mind spending my $100 over the many years it will take me to get 100 nights at 32 or less.
    ~Paul
    mas985's Avatar
    Pleasanton, CA
    11,743
    Quote Originally Posted by Jabooh1 View Post
    That doesn't sound like sleeping better to me.
    Mark
  20. Back To Top    #20
    Jan 2013
    Friendswood, TX
    320
    I don't stay up checking it. That would suck!
    I check it at 10 or so before bed.
    ~Paul
