Thread: Ballpark cost to replace a leaking skimmer
    Feb 2013
    Pleasanton CA
    18
    Hi,
    I live in Pleasanton CA where ironically it seems very difficult to get a reputable quote for replacing a leaking skimmer (crack on the side, plus also at the joint below it). After dozens of phone calls I got one quote for $2500 which seems outrageous considering I'm reading online it should be ~$1200. I currently have a very old U-3 blackbottom skimmer. This is the what they told me is included in the quote:
    Skimmer replacement includes:
    - Saw cutting the pool Kool Deck
    - Skimmer and cement collar removal
    - Drilling the pool wall to install new steel rebar
    - Skimmer installation
    - Epoxy new steel into the drilled pool wall
    - Installation of a steel reinforced cement collar
    - Plaster the skimmer throat
    - Patch the Kool Deck to match as closely as possible
    Is there something special about the work or my skimmer that could make it over 2x the cost??? Or am I incorrect and skimmer replacements are usually around $2500? If anyone also knows of someone reputable around the Pleasanton CA area I could contact for another quote, I'd greatly appreciate it.
    Steve
    Oct 2014
    Sacramento, CA
    72
    Re: Ballpark cost to replace a leaking skimmer
    I work in your area and thats around what i charge as well most companies i know charge around 2200-2500.00 its a lot of work and a pain in the butt.\
    David Randolph
    Warranty Station
    Pentair
    Jandy
    Owner Sac Pool Pros
