Thread: Freezing Temps - Clogged DE Filter
    Jan 2015
    Dallas TX
    2
    The pressure in my pool continues to be high after backwashing the DE filter. This just started yesterday. I pulled out the filter grid assembly yesterday evening and tried to was it off somewhat, but i have not had a chance to soak them to clean thoroughly. The temperature outside is getting down below 20 tonight and will be quite cold for a few days.
    Does anyone know if i can remove the filter grid assembly and just let the water circulate in the pool to keep it from freezing?
    Thanks!
    Re: Freezing Temps - Clogged DE Filter
    Welcome to TFP!
    Yes, you can remove one or more grids, leave them out and reassemble the filter. That will allow water to be circulated without being filtered. Note that if you don't also throughly clean the inside of the filter, you will probably get some DE in the pool. Of course DE in the pool is easy enough to fix when temps return to normal.
    The other option would be to do a quick winterization of the plumbing.
    Jan 2015
    Dallas TX
    2
    Awesome! Thanks for the info!
    Richard320's Avatar
    Jan 2010
    San Dimas, CA (LA County)
    18,967
    I'd guess your gauge froze and is reading wrong. After you backwashed, do you get good flow? Ignore the pressure - is there a normal amount of movement in the skimmer and from the returns? If so, order up a new gauge and just run the thing.
