Results 1 to 8 of 8
Thread: How to manage pool during freezes
    May 2014
    Houston, TX
    155
    I live in southeast Texas and we're supposed to have a night or two of below freezing temperatures. Do I turn the pump off overnight? Am I supposed to drain the pool a little? Any tips?
    IG gunite pool size: 12,500 gallons - includes spa with spillover, Polaris vacuum cleaner, Ultrapure Ozonator, inline tab chlorinator that I no longer use
    Filter: Hayward Swimclear Model #4030, 4-Cartridge Filters
    Pump: Century, 2 HP with a Hayward 6060 booster pump
    Date of build: March-April 2014 *NEW* : Test kit: TF-100
    Nov 2013
    Fort Worth, TX
    114
    Re: How to manage pool during freezes
    Quote Originally Posted by yardoasis View Post
    Temperatures near and/or around freezing for a few days should not cause any issues for you. If you did want to do anything with the pump, you would turn in ON to circulate the water. My advise.....relax.
    30,000 plaster in-ground pool with spa; 2.5HP single speed Centurion pump; Raypak RP2100 propane heater; Polaris 280 with pump, waterfall with separate pump, Triton II commercial sand filter; TF-100 test kit w/ SpeedStir
    Mod Squad zea3's Avatar
    Jul 2009
    Houston, Texas
    9,427
    The news this morning says the hard freeze warning is for those north of Harris County. Depending on which part of Houston you are in it probably won't be below freezing long enough for ice to form in your pipes, but if you want to play it safe you can run your pump all night. In our area the above ground pipes are the ones at risk, since our frost line is only 6" deep. Your in-ground plumbing will be well insulated by the dirt.
    Love TFP? Become a
    TFP Supporter!
    Jan 2013
    Friendswood, TX
    320
    I turn my on for the hours we are supposed to be at 32 or below. Freezing doesn't happen instantly either, think of how long it takes to make an ice cube in your freezer sitting well below 32*.
    The danger is an ice plug that is significant enough it can cause a blockage and expand to where it bursts the pipe. I doubt the 3 hours we have below freezing would do that.
    However for the $0.40 it will cost me to run my pump, I turn it on.
    ~Paul
    19x40 IG including 10' BE, 18,000 gal, plaster, 48 SF DE, 1.5HP pump, AquaPure SWCG, Ozonejoe 30MR, Rockwaterfall, LED light, TF-100 Fill date 11/21/2014
    My ODK Build | My Pool Build | If You're From Texas Vote Here
    Mod Squad JVTrain's Avatar
    Feb 2014
    Central Minnesota
    5,080
    As has been said, best to circulate pump continuously whenever freezing conditions are present. There's very little risk in your situation for the pool surface to freeze but what you need to be concerned about are the low volume areas that are exposed directly to the outside such as skimmers, above ground lines at the pumping station and the components at the pumping station (pump, filter, valves, etc.).
    Isolated Spa - 345 Gallons
    mas985's Avatar
    Pleasanton, CA
    11,741
    Quote Originally Posted by Jabooh1 View Post
    It won't. Ice plugs generally do not form below about 20F and in most cases will not form until well below 15F. Even at 20F, it takes a 2" pipe 16 hours to freeze with a 15 MPH wind. Here are a few other freeze times:
    http://www.troublefreepool.com/threa...eze-Protection
    Although somewhat warranted, most people are way too conservative when temperatures dip below freezing. It takes very extreme temperatures and/or very long freeze times before it becomes an issue. Exceptions are for smaller plumbing where shorter freeze times are possible.
    Mark
    Jan 2013
    Friendswood, TX
    320
    Quote Originally Posted by mas985 View Post
    Agree, but for $0.40 I'll run the pump.
    ~Paul
    Aug 2013
    dallas,tx
    79
    I see in your signature your pool was built last April. I would think that you have a freeze guard mode that kicks on depending what temp has been programmed. Ours kicks on at 35.
    2009 19k, IG, Quartzscape negative edge w/waterfall, 8' raised spa w/waterfall ,Pentair WF28 2hp, Jandy 1.5hp pump for water fall feature, Polaris 280 cleaner with booster pump,400,000 Jandy LXI heater, Jandy DE 60 filter.
