Thread: Automatic chlorine feeder?
    Dec 2014
    Frisco/Texas
    45
    I'm building a pool that has Hayward equipment. It is a chlorine pool so I'm wondering if I should have the PB install an automatic chlorinater.
    Any suggestions?
    Dec 2012
    Manassas Park, VA
    205
    Re: Automatic chlorine feeder?
    i am not entirely familar with a automatic chlorinater. Just to be sure is this something that will use liquid chlorine or will it be something that you load tabs or pucks into?
    25,000 gallon in ground white plaster- 1 1/2 HP Pentair SuperFlo pump - 60 sqft FNS DE filter (with FiberClear), 1999 Sundance Optima 850 hot tub.
    Manassas Park, VA
    We don't recommend using tablet feeders, which is what I believe you are talking about. However, they can be nice to have for things like vacations, so it is often simplest to let it be installed and then decide if you want to use it later.
    pwrstrk's Avatar
    Elverson Pa.
    4,758
    Have you done any reading in Pool School ?
    Here are a couple of articles to take a look at if you haven't already done so.
    ABC'S Of Pool Water Chemistry
    How To Chlorinate Your Pool.
    Jeff
    Jul 2014
    Peoria, IL
    389
    I am with Jason on this one. For as little as they cost have the PB install the puck feeder. You can run with it off line and BBB or Liquid chlorine sanitize. But if you BBB and want to go on vacation it will be nice to have the ability to throw a couple pucks in and be covered. If you plan on going SWG then never mind with the feeder.
    30x20 vinyl IG, Hayward SD60 with Pentair Dynamo 340219 2HP pump, Compupool CPSC24 SWG, Hayward H200FDN heater. APC automatic pool cover.
    Central Illinois
