Results 1 to 14 of 14
Thread: How often should a person shock their pool?
    I recently learned that the pool term "shock" is a verb not a noun. It means to add a lot of bleach to a pool right?? (I'm using the BBB method).
    I was wondering if it's recommended to shock a pool weekly, every other week, only after a really heavy rainstorm. When I shock my pool how much bleach should I add?? Am I basically trying to get a really high chlorine reading?
    I have a 30' above ground vinyl lined pool. Thank you everyone!
    Jeannie
    30' above ground pool, 20,000 gallons, BBB method
    Jun 2008
    Marana, AZ
    347
    Re: How often should a person shock their pool?
    Yes, shock is getting a high level of chlorine, and it is dependent upon your CYA level. There is no set schedule for shocking; after a heavy rainstorm or a high bather level is good. Otherwise, it's what you feel comfortable with. Some only shock once a month or less. Me, I try every couple of weeks, mostly because of the summer winds and rains we get here in the desert get stuff in my pool, as well as the fact I have babies swimming in my pool every so often.
    Above ground soft side Omega pool
    20 feet diameter, 4 feet deep
    Hayward sand filter
    Hayward 1 HP Matrix pump
    Hayward Aquabug Automatic Pool Cleaner
    Mod Squad JohnT's Avatar
    SW Indiana
    9,199
    You shock when you need it. That's when your combined chlorine is above 0.5ppm, or like Swimgirl suggests after young swimmers or any other event that introduces contaminants. I rarely shock my pool during the swimming season. I have once this year since I opened the pool, and often go through an entire season without shocking except when I open. The key is to know the condition of the water and do what needs to be done based on the test results.
    Butterfly's Avatar
    South Carolina
    10,045
    Hi Jeannie,
    I have only needed to shock my pool twice in the past two years.
    You can go to Pool School (link at top of each page in sub-heading & link in my signature) and read the article on "Shocking Your Pool".
    Most folks only shock their pool if the need arises, or if you are in doubt (found dead critter in pool ).
    Before/after rains, heavy bather loads, etc., most of us just increase the FC ppm a little to cover the need. Everyone soon learns the personality of their pool!
    You're done SLAMing when:
    frustratedpoolmom's Avatar
    SWSuburban Chicago, IL
    11,969
    Quote Originally Posted by Butterfly
    Me too, well, three times. Two vacations and closing last fall.
    searayboater's Avatar
    Jul 2008
    The Great State of Texas
    65
    I'll shock my pool once upon opening, once in the middle of summer, if needed, and once at pool closing. I open it the beginning of May and close it in October.
    18' AG Pool, 6900 gallons, 55 sq. ft. Hayward Easy Clear Cartridge Filter, 1hp Power Flow LX Pump, North Texas
    chiefwej's Avatar
    Jun 2011
    Tucson
    2,944
    My pool is open year-round, and in eight years I have NEVER shocked the pool. If the chlorine level is kept in range, the CC level is below .05, and the water clear, there is no reason to shock.
    chiefwej
    Aug 2010
    Dallas, TX
    4,052
    My answer is if you maintain the pool's FC correctly, the answer is NEVER.
    38,546
    Why are we answering a 5 year old thread?
    Aug 2010
    Dallas, TX
    4,052
    You are observant today Jason! I overlooked it completely!
    38,546
    Well, for full disclosure ... a newer member had asked a question here and gotten a few responses and I then merged all that back into their own thread. Sometime after that, chief likely responded to the question that was no longer here.
    Smykowski's Avatar
    Sep 2011
    3,065
    Moderator fail!
    (I'm guilty too! I almost responded but I didn't want to repeat chiefwej verbatim.)
    38,546
    Well chief responded a LONG time after I had already moved everything else. I almost moved his as well, but decided to leave it and then everyone started responding.
    I should just delete all this mess and move chief's as well
    linen's Avatar
    Jul 2010
    Twin Cities, MN
    8,649
    very sneaky jbliz...I got my eye on you
