Results 1 to 7 of 7
Thread: Shifted air pillow
    May 2014
    Clarksburg, WV
    331
    Shifted air pillow
    My pillow has shifted from the center all the way to one side of my 24' round AGP. Should I drain the water off the top of the cover and correct this or just leave it and tie it down better next year? The water on top has currently raised my water up to almost even with my skimmer basket. It was actually overflowing out the skimmer basket abit a few days ago. I drained a little off the top and now its back to about 2" below the skimmer.
    Should I drain and try and fix the pillow or just leave it for now?
    24'x54" 15k AG round - Outback Genesis
    1 1/2hp Hayward Matrix 2 speed. Hayward 180T Sand Filter
    TF-100 Test Kit
    Pool School & TF-100
    How to SLAM
    Jun 2013
    East TN
    309
    Re: Shifted air pillow
    1) Drain the water off the cover (as much as you can get)
    2) Loosen cover straps (Dont do this on windy days)
    3) Pull out air pillow and tie rope to both ends
    4) Put air pillow back in on one side
    5) Run one end of the rope under cover back to the opposite side and pull your pillow back to the middle
    6) Tie off both ends of rope with some slack in it
    No problem. I have done this before as you can see.
    18,000 Gallon Aboveground. Sand Filter with 2HP 2 speed Pump.
    May 2014
    Clarksburg, WV
    331
    Well, i put this off and put this off and ended up leaving it shifted to one side. Now my pool is chunk of ice and hopefully the pillow will at least do some of its job.
    Lesson learned....Dont be lazy...lol
    TF-100 Test Kit
    How to SLAM
    Casey's Avatar
    SW PA
    10,461
    I don't even use a pillow... Talk about lazy! lol
    Jan 2016
    Lowell, ma
    1
    Quote Originally Posted by kris77 View Post
    Hi kris77 - we noticed the same thing just now. It's encased in ice, too. Was there any damage to your pool when you opened for the season??
    May 2015
    NW Indiana
    22
    Mine is also off center, I don't know if the rope I tied it with broke or its just being pulled to the side since I left a bit of slack on the rope. I can't try to adjust it because there's a layer of ice on top of the pool cover.
    19K gal AG. 200 Swimpro Element Filter. 2HP, Dual Speed Voyager. TF-100.
    banditig's Avatar
    Sep 2015
    Ohio
    466
    Same problem my rope ripped through hole in corner of pillows on windy day.
    15x54 swim & play vinyl metal wall AG
    Hayward S210T sand filter 1.5 HP Pentair Superflo vs
    Rheem raypak 130,000 BTU mv ng
    Jacuzzi 345 whirlpool bath
    TF-100 test kit, HM digital com100 Wanda the Whale
