Results 1 to 10 of 10
Thread: Thinking of a new filter...
    I need to replace the inadequate system on my Intex 18’ X 48” above-ground pool. Currently it is the 1500 gph pump with cartridge. It also has a separate salt water generator.
    I was thinking the Hayward 100sqft Xstream 1hp Cart System. My current set-up has 1.5” fittings so I am hoping the setup would work with the SWG. Any suggestions or opinions?
    http://www.haywardnet.com/aboveground/p ... ductID=123
    Butterfly's Avatar
    South Carolina
    10,045
    Re: Thinking of a new filter...
    You're done SLAMing when:
    That looks like a good choice.
    It is always possible to adapt any kind of pipe/hose to any other, so I am sure you can hook up the SWG. Probably it will be simple, but even the worst case is just tracking down the right adapter.
    Found this site: http://www.flexpvc.com. Kinda pricey but has a great selection. I'll see what I can pic up locally but will probably use them for the specialty pieces unless someone has a better source.
    MikeInTN's Avatar
    Middle Tennessee
    1,335
    I've got basically the same filter. Here's a picture of how I've got my SWG plumbed in:
    The filter uses 1 1/2 inch fittings.
    FWIW, I like mine. It came with my pool, and it's worked great.
    24' x 52" AGP - approx 13,500 gallons
    Pentair Optiflo 1 hp/2sp pump w/ Swimpro Voyager 150 sq ft cartridge filter
    Intex 8110 SWCG
    "Fear the Schnauz!"
    Holy cow! It DWARFS the SWG! LOL
    I cannot wait to get this thing and plumb it in.
    searayboater's Avatar
    Jul 2008
    The Great State of Texas
    65
    I don't know if you are replacing the pump as well: http://www.poolproducts4less.com/index. ... ProdID=343
    18' AG Pool, 6900 gallons, 55 sq. ft. Hayward Easy Clear Cartridge Filter, 1hp Power Flow LX Pump, North Texas
    Jul 2008
    65
    I bought a filter combo from them as well, good prices! My water is crystal clear and that's with a 55 sq. ft. filter. Your's will be almost double that. You'll probably be able to go all season without cleaning it. I didn't clean mine until the middle of summer. It didn't need it though, I just did it to get familiar with it.
    That's a beautiful thing, man. This is my new hobby. I don't build ships in bottles or golf so I am happy to find something that appeals to my systems thinking and tinkering.
