Thread: Made an error during SLAM - Need advice
    Jul 2011
    Austin, TX
    61
    I am in the midst of SLAMing the pool I took a pH test and noticed it was super high. What I didn't realize is that the test is unreliable. The pH was 7.5 when I started. So, I added a bunch of acid to bring it down-which I don't believe was necessary. I expect that I'm somewhere around 7.0-7.2. Am I ok or do I need to counter balance this???
    Thanks
    16,000g in-ground plaster pool, attached spa, BBB, DE Filter, SWG
    Richard320's Avatar
    Jan 2010
    San Dimas, CA (LA County)
    19,009
    Re: Made an error during SLAM - Need advice
    How much acid did you add? If you plug the before numbers into poolmath and then scroll down to Effects of Adding Chemicals, it will tell you approximately what happened to the pH when you added the acid. If you're at 7 to 7.2, I wouldn't get excited about it. Just fix it when the SLAM is done.
    Patrick_B's Avatar
    Jun 2011
    Midland TX
    14,998
    If you think you added no more than that, I would agree.
    Essential Links:
