Thread: Need Help Comparing Pools
    Jan 2015
    Geneva NY
    1
    I have been looking at pools and have narrowed it down to two pool lines. They are both 24 foot round. The first company is Sharkline the version would be the Summerfield. That pool is about $2700 plus insulation that is $925 that only covers 4 inches of leveling with a sand filter. The second one would be Aquasports and the version would be St. Croix. That pool is $4500that includes insulation and it covers 12 inches of leveling. Also with a sand filter. Not sure which pools is the best I am a beginner when it comes to this any help/reviews would be much appreciated!
    Aug 2014
    Northern IL
    4,615
    Re: Need Help Comparing Pools
    Bump
    Mod Squad JVTrain's Avatar
    Feb 2014
    Central Minnesota
    5,080
    I have no experience with above-ground pools. I've heard good things on this site about Doughboy and Evolution AGPs.
    Use the search box in the upper right and see what you can find.
    I found:
    http://www.troublefreepool.com/threa...t-I-have-a-few
    http://www.troublefreepool.com/threa...e-ground-pools
    Also, browse the AGP forum section for other thoughts, ideas. http://www.troublefreepool.com/forum...e-Ground-Pools
    Search the forum for "Sharkline" and "Aquasports" might yield some good threads too.
    Isolated Spa - 345 Gallons
    jcowart's Avatar
    Jun 2012
    Labelle, TX
    320
    I don't know about the other manufacturers but DB pushes over sized pumps and under sized filters. Might look at packages without equipment or upgrade the package equipment.
    17500 gallon Doughboy AGP, Hayward DE filter, waiting for the 1.5hp DB pump to go out.
    Learn to take the advice here and be trouble free or use the pool store's advice. "You can't do both and get very far"
