Results 1 to 11 of 11
Thread: Do you turn on pool lights every night?
    ssml11's Avatar
    Jul 2014
    Miami/Florida
    131
    I currently have my hayward colorlogic turning on nightly, 7 days a week, from 6pm to midnight. Is that ok? Will I "burn" the light with daily use? I am wondering what everyone's light schedule here is.
    12' X 25' in-ground. Hayward EcoStar Pump, Hayward DE 3620 Filter, Hayward Pro-Logic PS4 with Aqua Connect for automation, Hayward ColorLogic Led lights, Silencer Blower, Four Jandy DeckJets, Salt Pool, Neverlube Valves with One Actuator. Built by owner.
    Jan 2013
    Friendswood, TX
    320
    Re: Do you turn on pool lights every night?
    I only turn mine on when I am outside to enjoy it. Incondecent lights have a number of hours and "starts" if you will. The filament can only take the inrush current so many times.
    LED lights don't care how many times you turn them on, it's more the number of hours that affect them.
    ~Paul
    19x40 IG including 10' BE, 18,000 gal, plaster, 48 SF DE, 1.5HP pump, AquaPure SWCG, Ozonejoe 30MR, Rockwaterfall, LED light, TF-100 Fill date 11/21/2014
    My ODK Build | My Pool Build | If You're From Texas Vote Here
    Divin Dave's Avatar
    Oct 2013
    Longview, Texas
    5,003
    LED's claim to last 50,000 hrs.
    I have one and it comes on every night. 7-10 in winter and 8-midnight in summer.
    Divin Dave,
    dumbcluck's Avatar
    Aug 2013
    long beach
    674
    so by that logic dave, they should need replacement in 35 years or so?
    -Jimbo- My pool was full of dirt and trees. Now it's full of water and children!
    20k gallon inground pool, 18" raised spa 7' round, 8 jets, 3" spa plumbing. Pentair intelliflo 3hp vsp, Easy touch 4 w/ ic 40, CCP 420 cartridge filter, Raypak 407a w/ cupro nickel, Screen logic 2, Pentair intelliph, spa side remote, Pentair 5g color lights pool and spa, TF-100 test kit with speed stir and Dolphin Oasis Z5
    Divin Dave's Avatar
    Oct 2013
    Longview, Texas
    5,003
    Dumbcluck, your math sounds right. They do claim the lifespan to 50,000 hours though. I doubt I will be around myself for 35 more years, But if I am and my light is still going, I will come to CA (or wherever you happen to be then ) and buy you a drink !!
    http://www.inyopools.com/Products/15...FYdaMgodOV0AgQ
    Divin Dave,
    dumbcluck's Avatar
    Aug 2013
    long beach
    674
    Thanks Dave. It is unlikely either of us will still be around but if we are ill take your drink and buy you two!
    Since you have put it in this light ( pun intended) I think I just might turn my led lights on a little more often so I can enjoy them before I go. I guess until now I didn't realize their life expectancy was longer than mine!
    Jun 2011
    Long Beach, CA
    2,781
    I don't think I've ever seen a light bulb last its stated life span, good luck on those 50,000 hours. There is a reason the warranty is nowhere near those 50,000 hours.
    Divin Dave's Avatar
    Oct 2013
    Longview, Texas
    5,003
    Dumbcluck, I like your way of thinking!
    I dont know really how long the light will last, but I am expecting to have to replace it every few years at least. Whatever the case my be, mine are gonna be on. Im like you, I wanna enjoy it all I can.
    Quote Originally Posted by dumbcluck View Post
    Divin Dave,
    Swampwoman's Avatar
    Apr 2012
    Grand Rapids, MI
    3,770
    Actually, with LEDs, they may well last 50,000 hrs, but they may also start to dim or cast a more pinkish color after 25,000 hours...which is why most don't warrant them for much longer than that.. In either case, the light is quite likely to outlast what its lighting
    In ground vinyl Grecian, 24k gal, Hayward 220t sand filter, VGreen VSP 165, Hayward SWG, Raypak NG 265k heater, dolphin m4.
    Helpful Links:
    GET A TEST KIT Chlorine/CYA Chart How to SLAM About Metals & Stains
    Jan 2011
    Richmond, Texas
    595
    I turn mine on almost every night. After having the lights installed almost 4 years I do have one issue with the big pool light where it looks like it lost a bank of LED's. So when it goes to blue it is very dim and not as bright as the spa size led lights. Still looks good and only I notice it
    Approx 11K Gal. 10'X30' Semi free-form IG - 6 ' raised spa w/6 jets - 10' circle sun shelf with 1 bubbler - Waterfall - 3 / 1.5 HP pumps - Polaris 280 Cleaner - 3 Pentair Color LED Intellibrite Lights - Pentair 400K Master Temp - 2 Valve Actuators - 5 Fiberstar Mini Laminars - 1 Fiberstars 2004 Illuminator - 2 Skimmers - 6 Returns - Caribbean Blue Pebble Tech - 600+ sq ft kool decK - Auto Fill - 2 Boston Acoustics VOYA RK5 Outdoor Rock Speakers - 2 TIC Corporation TFS5CN 6.5-Inch 150-Watt Terra-Forms Rock Speakers - Apple Airport Express - 1 Awesome View.
    borjis's Avatar
    Aug 2014
    Pacific NW
    2,318
    I have a 500 watt halogen in my pool, but only turn it on for show when guests are over.
    Next time it burns out, I'll be replacing it with an LED.
    Might run it every night then.
    Dolphin E10 Cleaning Robot.
