Thread: Polaris 280 keeps disconnecting
    Apr 2014
    NE Texas
    327
    This has happened about 4 times now. Everynow and then I'll see the line just floating in the water. I'll retrieve it with the pole, take a deep breath, and stick my arm down into the frigid water and screw it back in. How hard do I need to be twisting it into the connection?
    Kind of frustrating....
    Done! Pool build thread here
    38 x 18 free form, IG gunite with all gunite waterfall/slide/grotto
    18" raised spa, waterfall into pool
    Hayward 3hp Tri Star Pump x 3, 525sqft Swimclear filter, Polaris 280 cleaner
    Hayward LED pool lights, Hayward LED accent lights, 400K BTU Heater
    Patrick_B's Avatar
    Jun 2011
    Midland TX
    14,998
    Re: Polaris 280 keeps disconnecting
    Sorry I don't know, but I bet someone has run into this. Hopefully they will answer.
    Essential Links:
    Jul 2014
    Sacramento, CA
    241
    Is this the connector at the wall? If it's like mine (also a 280, but everything else about this pool is old and odd, so I'm never sure how standard things are), it's less than a quarter turn, and it's pretty obvious when it's on all the way. It's never come apart there (one of the mid-hose connections did come loose once). If anything, I find ours harder to disconnect than to connect (especially when the main pump is on with the boost off, but even with both pumps off). I wonder if either or both sides of the connector are worn and need to be replaced?
    21000gal IG plaster, Sacramento CA area (late 1950s/early 60s)
    Filter: Cartridge, Pentair CCP420 (2014)
    Main pump: Pentair IntelliFlo VS (2015)
    Boost pump: 3/4hp (2011), Polaris 280 cleaner (unknown age)
    Nov 2013
    Fort Worth, TX
    114
    Same question....are you talking about it disconnecting from the wall? If so, it is a push and twist connection. You have to push in hard and then turn a quarter turn. As jmastron reported above, mine is so hard to remove (even with both pumps off) that I really need to be in the water to get the hose off. Maybe you think you have it connected firmly but you don't?
    30,000 plaster in-ground pool with spa; 2.5HP single speed Centurion pump; Raypak RP2100 propane heater; Polaris 280 with pump, waterfall with separate pump, Triton II commercial sand filter; TF-100 test kit w/ SpeedStir
    Apr 2014
    NE Texas
    327
    Thanks for the replies so far. Just got back in from connecting it (FYI, water temp...39....
    It must be something wrong with the connector. When I slide it in and start to twist, it feels like its guiding its way in, but there never is a solid "click" or a feeling of secure connection. I tried twisting it hard...pushing...pulling...nothing. It just seems to sit in there without much security.
    I've got a few things for the PB to come back and fix and i'll make note of this.
    Thanks for the help!
