Results 1 to 17 of 17
Thread: 3 ton jumping rock/waterfall
    Mar 2014
    Angleton, Tx
    91
    Hi all, newbie from Texas. Not sure if this is the correct place to post or not. Just now putting things together for a build. My wife and I are thinking about a jumping rock/waterfall. The one builder we have spoken to suggested 3 tons worth of rock for the jumping rock/waterfall. Just wondering if someone has a picture of how large that is? We're have a hard time visualizing what this. Freeform pool 32x18 is what we're thinking. Any pics or Info would be greatly Appreciated.
    Patrick_B's Avatar
    Jun 2011
    Midland TX
    14,998
    Re: 3 ton jumping rock/waterfall
    Welcome to the forum!
    There will likely be someone who can picture you with something close. Your builder should be able to give you a good idea of dimensions as well.
    I know there is nothing like pictures though, so maybe someone will help you out. Good luck on your build, and enjoy the forum.
    Essential Links:
    Jan 2013
    Friendswood, TX
    320
    Hello!
    This is a 3 ton waterfall. I also have rock on either side.
    The "waterfall portion is really the width of the three main rocks (large ones in the pic) and the rocks above/below. The rocks on either side are additional.
    ~Paul
    19x40 IG including 10' BE, 18,000 gal, plaster, 48 SF DE, 1.5HP pump, AquaPure SWCG, Ozonejoe 30MR, Rockwaterfall, LED light, TF-100 Fill date 11/21/2014
    My ODK Build | My Pool Build | If You're From Texas Vote Here
    Mar 2014
    Angleton, Tx
    91
    Awesome! We were just looking at your build, our pool is designed very similar to yalls.
    Jan 2013
    Friendswood, TX
    320
    Glad I could help. You can't tell but there is a bench under the waterfall. You can sit on it and your head is under the center large rock.
    With that much length of waterfall (the three rocks worth) I can run the 1.5 hp pump on 1/2 or 3/4 flow (via a divert valve) and it is good. It's quite loud so with people in the pool I wouldn't want much more flow.
    Who is your builder?
    ~Paul
    Mar 2014
    Angleton, Tx
    91
    Were building a new home as well, and my builder Clint Peltier does pools for the homes he builds..
    Divin Dave's Avatar
    Oct 2013
    Longview, Texas
    5,003
    Hi itried!
    Welcome to TFP!
    Lots of folks here to help out with any questions you have, so don't be shy...
    Just let us know and we'll be glad to help.
    Divin Dave,
    Oct 2014
    Kingwood, TX
    100
    Quote Originally Posted by itried View Post
    Check out our pool we have a 4 ton and a 2 ton.
    Oct 2014
    Kingwood, TX
    100
    Quote Originally Posted by DoubleD View Post
    Jan 2013
    Friendswood, TX
    320
    I had my builder show me pictures of 3 and 5 ton waterfalls they have done then picked a couple I liked. It's also good to be home that day to make sure it's how you want it.
    ~Paul
    maxepr1's Avatar
    Mar 2011
    DFW
    716
    [IMG][/IMG]
    [IMG][/IMG]
    [IMG][/IMG]
    That's 6 tons of rock. The driving rock was 1500lbs. if I remember.
    40'x19' IG Diamond Brite 29K 4' Waterfall/Dive Rock FNS60 DE Inteliflo VS 2hp Whisperflo pumps Aqualogic(P4) SWG TF100 Tester
    Pool School, Pool Calculator,TFTestKits,
    s9601694's Avatar
    Oct 2013
    Conroe, TX
    90
    This is my 13 ton waterfall with 3 layers of jumping rock. Lots of fun!
    Check my pool build tread, it shows how it was built as well somewhat.
    http://www.troublefreepool.com/threa...Pool-Conroe-TX
    See my POOL!
    Free form pool, 128 ft perimeter, max length 42ft, max width 38.5 ft, depth 3.5 - 8ft, Chilean Beach Gold Pearl Matrix, 13 ton moss rock waterfall, tanning ledge with 3 gushers, PV3 i, LED underwater lights, automatic water leveling system, 1424 sqft deck.
    Mar 2014
    Angleton, Tx
    91
    Nice! thanks fellas
    Feb 2016
    Houston
    323
    Glad to find these photos. We may get a 3 ton waterfall/jumping ledge too.
    Feb 2016
    McKinney/tx
    36
    Love the greenery around your waterfall. Is the tree behind it a Crape Myrtle? Do you have issues with the blooms falling into the pool?
    Build in-progress, broke ground 3/16/2016, My Pool Build
    18x25 freeform IG gunite (13k gallons); waterfall, weeping boulders, rock wall spa w/ 8 jets
    Oklahoma Flagstone coping, Tahoe Blue mini pebbles
    Jandy Equipment (DE filter,var speed pump, JXi heater, Remote Automation;
    Tiger Lily's Avatar
    Mar 2016
    South Louisiana
    42
    That's beautiful! What color is your travertine coping (noche)? Also what color is your Spraydek...or is it Sundek?
    15 X 34 Pacific Blue Viking Fiji, 3'6" to 6', 12,000 gallon with spill-over spa wrapped in stone, 2 laminars, noche travertine coping, & spray deck patio. Hayward Heat Pump, SWG
    maxepr1's Avatar
    Mar 2011
    DFW
    716
    Quote Originally Posted by amethys08 View Post
    It's called a smoke bush. Blooms in the spring, leaves never completely fall off.
