Thread: New build patchogue
    Dec 2014
    Patchogue
    2
    New build patchogue
    Hey there! My 18ft above ground is about to bite the dust so I'm considering building a semi-inground flat bottom (due to high water table) build with cement blocks and a sand bottom. Would I be able to use an above ground pre-made liner (12 x 20) and build the pool to fit the liner? It would keep initial cost down and future replacement easier. I'm still in brainstorming mode and weighing out different construction materials and techniques. Any input would be greatly appreciated!!
    Sep 2013
    Dallas-Ft. Worth Metroplex, TX
    810
    Re: New build patchogue
    Welcome to TFP. Are you in Patchogue, NY?
    14K Freeform Gunite w/60% Blue Quartz plaster, Quad DE filter, Intelliflo VS Pump + Booster for Cleaner, Aquacal Heat Pump
    Dec 2014
    Patchogue
    2
    Quote Originally Posted by zethacat View Post
    I sure am!
