Results 1 to 11 of 11
Thread: Jets not working
    Dec 2014
    HYDE PARK
    5
    Jets not working
    NEED HELP. I have been trying, and trying, and trying to get my tub to prime, but due to what I believe is an air lock, the dang thing won't prime. I have emptied and re-filled three times. Once directly through the filter, once through filter and forcing water through the jets, and once directly into the tub. I have tried using a plunger to force air along. I have loosened two fitting: one before the heat pack and once at the high point entering the pump. Getting to the fitting at the end of the pump will be problematic. The error msg. I am receiving on the button panel reads "dr," which indicates "poor water flow or air bubbles." Nothing works. What am I missing? FYI - The pump is a Waterway Executive 48....the darn thing just makes a 'buzzing' noise for a few seconds, recycles, makes the noise again, and then shuts down for 15 min, and illustrates the "dr" message.
    Quote Originally Posted by Father of 1 View Post
    Thank you SO MUCH. I drained my hot tub refilled and have been trying to get the jets flowing in 40 degree temps for the past 6 hours until I seen your post! You are a life saver. We are leaving for a 10 day vacation in the morning and I was in a panic knowing temps will drop in the 20's at night while we are gone. The plunger did the trick!!! Thanks again!!!
    Swampwoman's Avatar
    Apr 2012
    Grand Rapids, MI
    3,763
    Re: Jets not working
    Just a wild-arrested-guess only because it happened to mine, but a new capacitor (not expensive part) fixed mine.
    In ground vinyl Grecian, 24k gal, Hayward 220t sand filter, VGreen VSP 165, Hayward SWG, Raypak NG 265k heater, dolphin m4.
    Helpful Links:
    GET A TEST KIT Chlorine/CYA Chart How to SLAM About Metals & Stains
    Dec 2013
    East Texas
    86
    Agree with capacitor. This is becoming a more common issue with A/C compressors as well. The A/C technician this past summer (when mine quit) told me that all manufacturers have outsourced to foreign production and there is no such thing as a "quality" capacitor available any more. Hopefully it's a different story for spa parts...
    30X40' free-form gunite/plaster pool, 4-8' deep with flagstone beach entry, gunite "rock" retaining wall with multiple small waterfalls/planters, grotto/slide/waterfall combo, 18" raised spa with waterfall into pool
    Swampwoman's Avatar
    Apr 2012
    Grand Rapids, MI
    3,763
    ^suspect it's not...mine was only two years old...the one before that lasted 15 years...sigh
    Helpful Links:
    Dec 2014
    HYDE PARK
    5
    Quote Originally Posted by Swampwoman View Post
    Errr. which means I have to pull the pump, which will be a process. If it is the capacitor then why is the pad reading "dr?"
    Anyone know what capacitor I will need for a Waterway? errrr
    Dec 2014
    HYDE PARK
    5
    Quote Originally Posted by geese2014 View Post
    Pulled the capacitor, ordered a new one, and will inform you all when it is installed. Thanks for the input. Keeping my fingers crossed it works.
    Swampwoman's Avatar
    Apr 2012
    Grand Rapids, MI
    3,763
    Maybe if you google your maje and model to get an owners manual you can look up the part somewhere like guileless or spa depot.
    Helpful Links:
    Dec 2014
    HYDE PARK
    5
    Found the correct part number, pulled the capacitor, replaced the capacitor with a new one, and the same result. Could this be what I originally believed: air lock???? Would draining the thing again and blowing out the lines with a shop-vac help? At a total loss on what to do or check next.
    Dec 2014
    HYDE PARK
    5
    Anyone? Anyone? Would love your input before I take the chainsaw to the thing
    mas985's Avatar
    Pleasanton, CA
    11,737
    Does the motor ever spin up or is stationary when it makes this noise?
    Mark
    Kiss4aFrog's Avatar
    May 2013
    Hudson, WI
    2,680
    From the "buzzing" and it shutting down for 15 minutes (overheats, thermal breaker, cools, resets) it sounds like you might have a bearing that's seized up and the motors shaft isn't turning.
    Might be worth digging into the pump to see if anything is jammed in the impeller or if the motor is seized.
    Solar Blanket, Well Water, Borax Added. 68
