Thread: NewB with Hayward Aqua Plus question
    Dec 2014
    Calabasas, CA
    1
    Just put in a new Hayward system and am having trouble (or doing something wrong) activating Spa heater. At night I'm going out, turning the filter on and pushing the pool/spa button so setting is on "spa." The jets turn on and everything looks fine, but the heater isn't kicking on.
    The only way I've found to get the heaters working is to flip the circuit breakers, turn everything off then turn it back on again. Am I doing something wrong in activating the spa?
    What I haven't tried is flipping the system over to "spa" during the day when the filter is already running. So don't know if this is a heater problem or "after hours" user error by me.
    Any help would be appreciated.
    ps0303's Avatar
    Jul 2011
    FL
    3,701
    Re: NewB with Hayward Aqua Plus question
    How is the heater connected into the Hayward controller? Did you configure the controller for the heater option?
    Paul
    http://www.gastekservice.com A word of caution: When working with gas and electrical you might want to consider a licensed contractor. Consider the value of your life and others around you. If you would like to provide a review of the help I provided, please use the following link to leave a review. gastek - Google Search,
    Welcome to TFP!
    Has this worked in the past? Or is it a new setup? Or new to you?
    Depending on the heater, the heater may need to be configured for external control, or set so that it always starts heating right away (by setting the goal temperature very high).
