Thread: How long do you wait between adding different chemicals?
    Hi everyone
    When I was buying my pool chems at a pool store I was told to wait 2-4 hours between each chemical I was adding. With the BBB method do I still have to wait that long??
    Thanks in advance for your answers!
    Jeannie
    30' above ground pool, 20,000 gallons, BBB method
    Jun 2008
    Marana, AZ
    347
    Re: How long do you wait between adding different chemicals?
    At least wait 1 hour between adding bleach and muriatic acid. Otherwise, you can make chlorine gas. That's bad news. Other than that, I don't know of any wait times between adding chemicals.
    Above ground soft side Omega pool
    20 feet diameter, 4 feet deep
    Hayward sand filter
    Hayward 1 HP Matrix pump
    Hayward Aquabug Automatic Pool Cleaner
    The only time you need to wait longer than an hour, with the pump running, is when adding calcium. You don't want to do anything that raises the PH for 24 hours after adding calcium. So no borax, PH Up, soda ash, washing soda, baking soda, cal-hypo, or bleach for 24 hours after adding calcium.
    Jun 2008
    Marana, AZ
    347
    Why's that?
    Hayward sand filter
    Combining calcium additions and PH increases tends to lead to calcium clouding. If your calcium saturation index (CSI) is very low this is not a problem and there is no timing constraint. But as the CSI increases it is more difficult for calcium to remain dissolved in the water. As you add chemicals, they don't mix throughly all at once. There can be spots in the water that have locally high CSI values for a period of time, which will precipitate calcium particles, which can cause white clouds in the water or calcium scaling on the pool surfaces.
