Results 1 to 7 of 7
Thread: Hello from Northern California
    Dec 2014
    Linda, Ca
    13
    Hello from 50 miles north of Sacramento. Have had the pool for 3 years now. Was totally pool stored. They tested the water for free and said buy this and add that. We did that and fought algae twice or more a year. Our algaecide bill was through the roof. Well the pool store went out of business. Came across this site and read pool school. I want in. I got the tft-100 testkit and tested the water. No wonder we fought algae. All the levels are off and the cya is high as the sky. I think a partial drain and refill is my starting point. Get ready for the questions after that!
    Can't wait for warm days and sunny rays.
    Thanks in advance for the help
    14500 gallon, 24' round vinyl agp buried, pentair tagelus 60 sand filter, max-flo vs sp2302vsp, TF-100 testkit
    pwrstrk's Avatar
    Elverson Pa.
    4,758
    Welcome to TFP.
    Your off to an awesome start. Got the best test kit and have done your homework in Pool School.
    Your starting out on the right foot with replacing water to get your CYA level back in range. Keeping your FC in range for your CYA level is key to preventing algae outbreaks.
    Any questions you have don't hesitate to ask.
    Jeff
    Divin Dave's Avatar
    Oct 2013
    Longview, Texas
    5,031
    Re: Hello from Northern California
    Hi rig,
    Welcome to the world of easy and algae free pool care. And for cheap to boot!
    There's nothing like your own high class test kit and knowing what the water parameters should be. Is there?
    let us know if there are any questions you need help with.
    Divin Dave,
    Butterfly's Avatar
    South Carolina
    10,045
    Welcome to the forum
    You really are hitting the ground running
    You're done SLAMing when:
    Patrick_B's Avatar
    Jun 2011
    Midland TX
    14,998
    Quote Originally Posted by Butterfly View Post
    Indeed!
    Welcome to TFP! Glad you found us!
    Essential Links:
    Mod Squad kimkats's Avatar
    Jul 2012
    Tallahassee, FL
    30,672
    SWEET! You ALREADY have a test kit?????????? You will have so much fun with your pool now that you are not always working on it or paying MORE money for stuff that really does not work.
    Let us know if there is any way we can help you.
    Kim
    Aug 2011
    Central Valley California
    121
    Welcome.
    23,000 gal IG Plaster 1989
    Purex Triton FNS Plus DE Filter Model FSNP 60
    1 Hp pump, Polaris 380 w/booster pump
    700 Gal Spa
    Laars Lite Heater T-F 100 Test Kit
