Thread: Iaqualink........not working properly
    Dec 2014
    Melbourne Victoria, Australia
    18
    Hi All
    First Id like to say thanks to everyone for their help, I'm only
    new here and its been fantastic.
    I have another problem.
    The electrician wired 3 double power points to my iaqualink
    lets call them( 1 , 2 ), (3 , 4) ,( 5 ,6) they should all correspond to the aux # in the control box.
    after plugging in the plugs i have noticed the following
    If I use plug 1 and plug 2 (which is a double) only 1 of the plugs will work at a time
    Plug 3 is taken up by the spa spillover (the JVA'S) ALSO plug 4 will not work
    However Plug 5 and 6 will work together (however they don't match the aux#)
    if any of this makes sense to you that would be great to hear from you
    larso
    Re: Iaqualink........not working properly
    There is no standard for how plugs/sockets get wired. The electrician could have done just about anything, and if it has been around for a while it could also have been modified afterwards for any number of reasons. The only way to know what is what is to trace the wiring.
    1 & 2 sound like they are designed to control a two speed pump. Do you have a two speed pump?
    It would be easier to answer your questions if you kept everything together in one place. The information you have in your other threads would of some help in answering these questions, but it is a fair bit of extra work for us to go looking for it.
    Dec 2014
    18
    Thanks Jason ....All good have the Iaqualink working perfect now.
    Jason,
    Now I have a problem with the jets in the spa,
    only 4 of the 7 jets work properly.
    I have a Booster pump 2 hp Hayward super 11 dedicated to the spa
    but when i turn it on only 4 jets hove good pressure the other 3 only slight pressure
    When I turn on the blowers they all work great.
    Does anyone know what this could be.
    Should I start another thread for this or leave it here.
    Regards
    Larso
    Oct 2007
    Parkland, FL
    752
    Quote Originally Posted by larso View Post
    Jason,
    Regards
    Larso
    Not sure I understand what you are saying, they should have very little pressure if the blower isn't on. If the blower is on and they don't have pressure then I assume there is a blockage. I just moved to a new house that has a blower and one of my jets out of 6 is also a bit weak, I'm thinking there is debri in there but I'm not sure if they have venturis like my old spa with no blower but I"m guessing they do. Its like a 5/8th or 3/4 socket should unscrew the venturi, need like 2 extentions to get into the jet to get to the venturi. When I took it out at my old house, a big piece of plastic came out.
    8000 gal diamond brite pool with 650 gal spillover spa, Pentair 3hp VS pump. Jandy Cartridge filter and Jandy Heat Pump. Jandy PDA automation system with 2 Pentair Laminars. SmartPool NC74S Robotic Pool Cleaner.
