Thread: Poolskim return jet
    Curtsam's Avatar
    Aug 2013
    Eastern Oklahoma / Arkansas
    33
    Poolskim return jet
    I just received a poolskim and have a couple of questions please.
    I took off the return eyeball and need to know the best way to unscrew the rest of the return assymbly in pool to attach the poolskim. I can't take it off by hand; do I simply use a pair of pliers to unscrew? I just don't want to rip the liner or break it.
    Any problems using glue for the pvc assymbly or are the screws that come with it sufficient.
    Thanks for any response and have a great new year!
    2014, IG 20,000 gl 18x34 Vinyl Liner / Waterfall / SWG / Sand Filter /
    Dolphin M4 Robot / TF-100 Test Kit is used / Beer is consumed /
    *Stamped Concrete Decking*
    Re: Poolskim return jet
    A strap wrench is a good way to get the remainder of the fitting out.
    Mod Squad zea3's Avatar
    Jul 2009
    Houston, Texas
    9,376
    I would not glue it together. You need to be able to adjust how the pieces fit together and the stainless steel screws will hold it together just fine as long as you make sure the screw goes through both pieces of pipe. Don't try to use power drivers to put it together or you may crack the pipe.
    Love TFP? Become a
    TFP Supporter!
    Curtsam's Avatar
    Aug 2013
    33
    Thank you both!!
