Thread: Where do I drain pool water?
    Carolwoodpacific's Avatar
    Dec 2014
    Clermont, Florida
    18
    Is pool water safe/legal to pour into my yard?
    If not... Is a residential plumbing system and city sewer up to the task of accepting the large volume of water a pool pump produces?
    Joe
    7000 gallon IG pebble tech (31X7.5 feet) Built 1998.
    Hayward Star Clear Plus C900 cartridge filter with 1 1/4 HP pump.
    TF-100 with speed stir. Liquid chlorinated.
    Re: Where do I drain pool water?
    Safe, sure. Legal, that varies from place to place.
    Jun 2011
    Carlsbad, NM
    171
    I backflush my filter to my grass with no ill effects. I do not shock my pool though.
    36' x 18' 20k in ground, Finest Finish grey plaster, Pentair Tagelus 100D sand filter, Hayward Northstar 2hp pump, Jandy LRZ125EN heater, spill over spa, iaqualink controlled automation, Stenner chlorination, natural rock and flagstone coping, 1" glass mosaic waterline tile, SR Smith Vortex slide.
    Mod Squad JVTrain's Avatar
    Feb 2014
    Central Minnesota
    5,080
    Local codes vary quite a bit based on where you live. Most small cities will say in your yard is fine, just avoid flooding anyone else's property or draining directly into a street or surface water sewer. Other cities mandate that it be dumped into the municipal sewer system. I'm sure there's even some city in California that requires you have it pumped onto a truck and disposed of as hazardous waste at your cost, plus a municipal fee of $1000 so look into your local codes concerning pool operation and water.
    Isolated Spa - 345 Gallons
    jrs_diesel's Avatar
    Aug 2014
    League City, TX
    215
    Just look up the municipal codes and laws for your town/city.
    Mine says anything goes as far as draining, just not down the storm drains. I usually just drain to sewer, I have a hose that reaches a cleanout on the back of my house.
    J.R.
    20K IG gunnite pool
    2HP Hayward single speed pump
    Cartridge filter
