Thread: Acid Feeder upside down. Help
    Dec 2014
    Melbourne Victoria, Australia
    18
    Hi
    Having problems with pool plumbers not turning up decided to finish
    all the plumbing myself.
    After reading the manual for the Puresilk Chromatalyzer it states that the acid flow with on the return
    line be installed T down (below pipe) I noticed the pool plumber has plumbed it T up (Above pipe)
    Will this still work????
    Larso
    Re: Acid Feeder upside down. Help
    The acid feed T orientation shouldn't matter. It is important that the flow switch be mounted below the pipe, but the acid injector connection shouldn't matter.
    Dec 2014
    18
    Yes the flow switch is below, its just the acid injector that is above the pipe.
    Thanks for your help
    larso
