Thread: Patent on removing CYA from the water
    Jul 2012
    Central Texas
    436
    Side conversation spit off of this post. JasonLion
    Thers a patent application out there for using melamine to reduce CYA.http://www.google.com/patents/US20130186837 have absolutely NO idea as to its status or viability. Just thought it was an interesting search result. Apparently green water is a by-product (so says the application) which would be disconcerting even if it worked.
    Central TX / 12K GAL / IG / SWG / DE filter / Pentair SVRS & 3 swim jet pumps / Spa bench and jets / Single body of water / No heater.
    Re: Patent on removing CYA from the water
    While that does work in principal, it works out very very poorly in practice. There was a product based on that patent, but it was very expensive and tended to leave the pool cloudy in a way that was very difficult to clear up. They eventually took it off the market.
    Jul 2012
    Central Texas
    436
    Ok. Thanks. Good info. I certainly wasn't promoting it... Just saw it as an interesting result on a search.
    38,487
    I believe the cya test is a similar (same?) process. Turn the pool cloudy then try to filter it out. Does not sound like it worked very well or they would be billionaires.
