Results 1 to 10 of 10
Thread: Merry Xmas all!! Pool cleaner question
    Themacdadt's Avatar
    Sep 2013
    Cocoa, fl
    112
    wife just got me a hayward navigator pro. It's in pool now and appears to be working. My question is should I leave it the pool 24-7? My pump runs four hours a day so the cleaner will only run four hors a day but is it ok to leave in the pool when not running? Thanks all!!
    Thanks Todd.
    15,000 gal. In ground, sand textured with beach area, spa located in beach area with spillover equal to pool level.Rock waterfall with 4 foot drop.Hayward goldline aquaplus automation all wireless remote.T 15 cell,Propane heater,Super 2 for pool/spa,Super 2 for waterfall.Cartridge filter and solar panels.
    30,431
    Re: Merry Xmas all!! Pool cleaner question
    It seems we all do different things. I used to leave my first cleaner years ago in 24/7. The more I thought about it, that didn't seem like a great environment (soaking in the pool) for anything that had seals.
    I now take mine out of the water after each cycle. I am not sure if there is a perfectly correct answer but I rest a little easier with mine being removed when not in use.
    Themacdadt's Avatar
    Sep 2013
    Cocoa, fl
    112
    Sounds good, anyone else?
    Thanks Todd.
    Oct 2007
    Parkland, FL
    752
    I leave my robot in 24/7. Taking it out killed the seals faster than anything else
    8000 gal diamond brite pool with 650 gal spillover spa, Pentair 3hp VS pump. Jandy Cartridge filter and Jandy Heat Pump. Jandy PDA automation system with 2 Pentair Laminars. SmartPool NC74S Robotic Pool Cleaner.
    Jul 2014
    Orlando, FL
    12
    I leave mine in the water 24/7, but I have a valve on a timer to run it just 45 minutes each day. I'm in a screen, so the pool doesn't require much cleaning. The limited run is for two reasons: 1) It takes away from the skimming action and I want to maximize that, 2) pound-for-pound, pool parts are the most expensive product on plant earth and I want to minimize wear on the cleaner movables.
    10,000 gal in-ground; 1hp single speed pump; Puck chlorination; Pebbletek; Hayward C1200 filter. Coming: solar, Intermatic PE953RC and Z-wave.
    30,431
    The last two posts in this thread indicate most pool cleaners have more longevity by leaving them submersed. I cannot scientifically challenge that but it seems to me not as logical as removing it.
    A suction cleaner or a booster pump cleaner has no onboard motor so waterproof seals are non-existent. A robot, however, has onboard electrical and must remain waterproof in critical areas. My assumption is that chlorinated water will take a toll on those seals and eventually cause them to fail.
    Maybe not, but seems to make sense. Over a long enough period of time, chlorine can begin to eat away at many, many things.
    wjr75's Avatar
    Jun 2013
    IL
    836
    When I have the pool open in the summer I keep my Polaris280 in the pool all the time unless I have a party then I take it out.
    Inground 22k gallon gunite 15x31 main pool, 15x7 wading pool/sunning deck, hot tub/with overflow (9' octagon with limestone top) & slide NSWG, Aqua Blue Pebble Sheen
    Filter dual cartridge Sta-rite 450sq/ft, TF-100 Test Kit
    Heater Raypak 2100 400k btu cupro-nickel exchanger
    Auto pool cover, Polaris 280 auto pool cleaner, Jandy AqualinkRS8 Remote Control System
    Apr 2014
    Austin TX
    10
    I leave my Polaris 280 in all the time and set it to run for just one hour every day. The only time I remove it is when I expect more than a few people to be swimming that day. I've had to replace the bag on it each season so not sure if the bag degrades more when constantly submerged but they are inexpensive.
    _____
    18k gal in-ground plaster pool+spa, 2HP Jandy pump, 460 sqft Jandy cartridge filter, AquaPure 1400 SWG,
    3/4HP cleaner pump, Polaris 280 cleaner, Jandy LX heater, 2HP air blower, FlowVis check valve, iAqualink, TF-100 test kit
    Oct 2007
    Parkland, FL
    752
    It depends, I live in Florida and if I take the pool cleaner out, while it might be covered, it still is usually in the Sun, so come out of pool, heat up, go back in pool cool down, one robot broke every 3 to 4 months, that same robot when I finally just left it in lasted another 1 1/2 years or so and it was already on its last legs the last time it was repaired. Now if you take your robot out and store it in your garage every time, then it will probably last longer, but I'm guessing most people really aren't going to do that every time.
    pragmatic's Avatar
    Jul 2011
    Friendswood, TX
    521
    I have the same suction-cleaner. Stays in the pool and removed only when swimming and during SLAM. I've had only one minor-maintenance issue in 3 years (A-Frame bearings). It's a work-horse; IMO the best bang for the $. FWIW-My Navigator saga er learning-curve http://www.troublefreepool.com/threa...ight=navigator
    Dave My Pool Build, ODK Build
    22X42 Gunite Freeform 23K Gal, 10X12 Spa
    Diamond-Brite midnight blue, 1800sq. ft Kool Deck
    Pentair Easy-Touch 8, 2-2hp Pentair, 500lb Sand Filter, 400K btu Pentair heater
