Thread: Dumb Question on Speed Stir
    Jun 2014
    Sanger, TX
    555
    Okay friends, this is a dumb question, but my husband isn't home and I don't want to wait to use my speed stir. What kind of tool do I need to loosen the screw on the back to put the batteries in? I am hoping I don't have to find one of those small "eye glass" screw drivers. I've tried a knife tip and that's not getting enough traction. Does anyone have any secret tools they used besides "the right size screwdriver"? - Thanks, Karen
    New in 2017, will update
    38,271
    Re: Dumb Question on Speed Stir
    Sorry, I think you need to find the right tool ..........
    EVChargeGuy's Avatar
    Jun 2014
    Long Island, NY
    340
    A very small Phillips head
    IG Tear Drop, Dark Gray Gunite , 27,000 gallons -Age 50+-years, very old Hayward Split Egg Sand Filter with side mount Multi-port- Hayward SP2600VSP Pump- Hayward chlorine feed (not used since finding TFP) - Laars 315K BTU Oil heater- LoopLoc Safety cover- AquaBot RAPIDS 4WD- TF-100 Test Kit w/ Speedstir- 390 Gal Hot Springs Spa Envoy installed May 2017
    Richard320's Avatar
    Jan 2010
    San Dimas, CA (LA County)
    18,984
    That's a #0 Philips screwdriver. Once you get the screw out, leave it out. My lid stays put without it, not even any tape. The alternative is a drill bit to just remove the head and be done with it.
    Jun 2014
    Sanger, TX
    555
    In case anyone cares - I ended up using a Stanley #1 Phillips head screwdriver. Luckily, my husband has the tool drawers in his workshop very well labeled! Now I'm going to test some water - Karen
