Results 1 to 9 of 9
Thread: Help with changing pump strainer basket
    Dec 2014
    Ventura, CA
    4
    My husband and I just bought a house with a pool two months ago. I am in charge of the pool while he is doing the lawn/garden. Luckily I found this site and have been able to figure out how to keep my pool from going green. It seemed so overwhelming but I think I understand most of the pool math so my pool is within the suggested range.
    So now I am trying to figure out how to change the pump strainer basket, which is full of leaves. I think it is affecting the pressure because the filter used to go up to between 10 and 15 and now it only goes up to 3. I took pictures of my pool equipment.
    Do I first turn off all the circuit breakers?
    Then do I open the filter valve (the black knob at the top)?
    Do I do anything else before opening the strainer basket top?
    The home owner before me briefly explained the pool equipment but warned me several times to be careful whenever you work with the filter because if something is attached incorrectly part of the filter could blow up and kill someone because of the pressure. So now I am a little worried about working anywhere near the filter.
    If the first part is correct, then I dump water back into the strainer basket? Do I tighten the filter first or do I start the pump and then after the air is let out then tighten the knob? There is a switch that I don't understand how it is connected to everything but it says prime.
    Any help would be appreciated.
    Re: Help with changing pump strainer basket
    Welcome to TFP!
    First turn off the pump. There are several ways to do that. The best is usually to put it into service mode using the pumps control panel. Then open the pump strainer basket, clean out the basket, and close up the lid again. Finally turn the pump back on (by reversing whatever you did to turn it off).
    Richard320's Avatar
    Jan 2010
    San Dimas, CA (LA County)
    19,073
    What he said ^^^
    That strainer lid will likely be a bear to get off. I give the ears a couple taps with a mallet to get it moving. Clockwise tightens, counterclockwise loosens. Taps, not hefty swings.
    And when you reassemble it, make sure there is no leaf residue or blades of grass on the sealing surface. After you restart it, it can take a few seconds - feels like longer - to prime and get going. Once it's going steady and the bubbles have pretty much disappeared in the lid, then crack the air bleed and vent any air that got inside the filter.
    It probably took me longer to type this than it will take you to do it. It's really not all that hard. You can minimize the amount of crud that gets in there by fitting the skimmer with a "skimmer sock". I use a queen-size knee-hi nylon like so:
    More pictures
    Dec 2014
    Ventura, CA
    4
    Thanks for replying so quickly. So I don't have to worry about opening the filter valve or turning off the circuits? When I tried to open it last month, I wasn't able to and my husband quickly tried. I am not sure if it was screwed on really tightly and my husband just needs to work on it or it was difficult to open because of the pressure.
    Thanks again.
    Dec 2014
    Ventura, CA
    4
    What he said ^^^
    More pictures
    Where do I find the air bleed to vent the air?
    Richard320's Avatar
    Jan 2010
    19,073
    Quote Originally Posted by SoCal Mom View Post
    Thanks again.
    It's like a jar lid, only a quarter turn or so. But it can get really tight. As long as you don't have an above-ground pool where the water level is above the pump, you probably won't have any problem. You might hear some glugging while things are opened up. It's normal.
    The air bleed valve is normally on the very top of the filter. The only exception would be if the top of the filter is also the multi-position main valve, in which case there isn't an air bleed.
    Dec 2014
    Ventura, CA
    4
    Thank you so much Richard 320 and JasonLion - I love this forum. My first post and my problem was immediately solved. I was on the verge of calling a pool man to come out because the pressure was so low and the Kreepy Krauly had stopped working. The basket was completely full of leaves and debris. It did end up being easy to clean out. Thanks also for the heads up that it would make a gurgling sound. The pressure is back up to where it was before and the Kreepy Krauly is making the clicking sound and vacuuming again.
    Richard320's Avatar
    Jan 2010
    19,073
    Don't forget to bleed the air out of the filter.
    There's always this, too:
