Thread: Cover lift for fiberglass spa?
    I have an older fiberglass tub and was wondering if the cover lifts would work with fiberglass? I know that you have to drill holes for the brackets and was concerned about whether you can drill holes into the side of the fiberglass and if it would hold the brackets. Any help or recommendations are appreciated.
    Patiently waiting for an in-ground oasis.
    Oct 2007
    Va Beach, VA
    41
    Re: Cover lift for fiberglass spa?
    I wouldn't. Is it on a deck? I have a odd shaped fiberglass hot tub on a wood deck and want to put a cover lift on it. I was looking at this one: http://www.spadepot.com/shop/CoverUp-X- ... 17C49.aspx
    Just haven't gotten around to buying it yet.
    BBBB?-Bleach, Baking Soda, Borax, BEER!
    18' x 33' x 54" AG Pool, Vinyl Liner
    17,700 Gal
    Pump: Baquapure Workhorse Superflow, 2.5HP, 2 Spd
    Filter: Baquapure High Rate Sand Filter, 26 inch
    Baquapure Water Polishing System
    Proud new Papa of a Pool Rover Junior! Born 6/20/08
    sammm's Avatar
    North Richland Hills, TX
    257
    I had these on our old hot tub. Not a lift, but work almost as good!
    http://www.spadepot.com/shop/The-Cover- ... 18C49.aspx
    WetEdge Satin Matrix, 16K gallon, Pentair NSP-60 DE filter, Pac Fab Challenger, 2HP pump, BBB, Polaris 360
    meatloaf's Avatar
    Feb 2008
    Gilbert AZ
    373
    I made mine from 1" PVC.
    My pool is a 10,500 gallon (420 Sq Ft ) kidney shape. STA-RITE HRPB30, Sand filter 30" 98 GPM, 1 HP Maxi-Glas 2 pump, BBB Method, Taylor K-2005 test kit, 50 Watt 12V low-voltage pond light illuminates the pool at night for a nice soft glow.
    spishex's Avatar
    Oct 2008
    Hillsborough, NC
    1,375
    You can always do what most stores do for floor models: Instead of mounting the brackets to the spa, mount them to a 2 x 4 on the ground just behind the spa. You'll have to devise a way to hold it vertically depending on your set up, but again nothing a little extra lumber can't fix.
