Thread: Water Feature Pump Size
    Dec 2014
    Melbourne Victoria, Australia
    18
    Hey Guys,
    Well finally got water in the new pool , hopefully all the equip will be up and running
    by this week.
    I connected the Pool water feature which is 2200mm Wide and 1800mm above the water line
    it is a stainless steel spillway that I only wanted to trickle down the feature wall.
    It runs on a Hayward super 11 316 pump 1 1/4, the flow seams to be to fast as it is not trickling
    Can anyone suggest what size pump I should be using.
    [IMG][/IMG]
    30,414
    Re: Water Feature Pump Size
    Can you manually restrict the outflow to slow it down? That won't hurt the pump.
    Dec 2014
    18
    Im not sure if that is possible is it? How would I do that?
    Cheers
    larso
    Jan 2013
    Friendswood, TX
    320
    There would be a valve on the piping between the pump and the water feature.
    ~Paul
    19x40 IG including 10' BE, 18,000 gal, plaster, 48 SF DE, 1.5HP pump, AquaPure SWCG, Ozonejoe 30MR, Rockwaterfall, LED light, TF-100 Fill date 11/21/2014
    My ODK Build | My Pool Build | If You're From Texas Vote Here
    Dec 2014
    18
    Hey Guys,
    Thanks I put a 3 way valve on the return line with a run off to a unused solar return
    worked perfect.......can adjust the flow of water easy.
    Thanks
    Larso
