Thread: My New Michigan Pool
    Greetings! We just bought a home and it came with a big above ground Doughboy oval pool!
    It had not been used or covered for a couple of years - there was an incredible amount of leaves and muck in the bottom. I didn't take a before picture because it was just to nasty to show anybody.
    The fine folks at TPS (Yes, i've been lurking!) suggested we just change the entire liner and start anew, and to be honest if we were on city water it probably would have been the most cost effective method.
    But we have been scooping and vacuuming for 2 weeks now, and we can now see the bottom. Time to start scrubbing, it appears.
    Of course, all this is just in time to get the pool winterized.
    ~17,500 gal outdoor 18'x34' oval Doughboy pool; Haywood 1 HP Super pump; Haywood Pro-Series Sand filter
    frustratedpoolmom's Avatar
    SWSuburban Chicago, IL
    11,969
    Re: My New Michigan Pool
    Welcome!
    Butterfly's Avatar
    South Carolina
    10,045
    Hi indyattic,
    Just think how much Sring opening work you have saved yourselves!
    Welcome to the forum!
    You're done SLAMing when:
    Butterfly, that very thought is what kept me going! Plus, even scooping muck from a puddle is better than being inside doing laundry.
    krcossin's Avatar
    Detroit Burbs
    113
    Thanks for cleaning that thing up, way less mosquitoes now! jj.
    Welcome... let's hope our summer goes into October so you can get some swimming in this year!
    2007 - 24' AG Doughboy Desert Spring dished 1.5', with DB Power Pak II-1hp pump, DB Sequel I Plus DE, Hayward H-Series Heater 100k + 8gal LQ.
