Thread: DIY Pool Timer Install
    My next DIY project will be installing a pool timer with freeze protection. Just wondering if anyone had any advice on a good solid timer. Theres alot to choose from over the internet, and would like to get some suggestions on which brand or brands are known to have decent product.
    ETA: Timer would only control pool pump. I have no other features.
    thanks!
    20,000 GAL, 16 X 32 IG Vinly Pool, Sand Filter, & 1.5 HP Hayward - Hot Spot Relay Hotub
    N. Mississippi.
    Dec 2014
    Houston, Texas
    134
    Re: DIY Pool Timer Install
    What controls the pump currently and what voltage are you working with?
    Its a 240v set up. Currently the pump is controlled by a simple on/off switch that resembles your common light switch.
    N. Mississippi.
    Killer95Stang's Avatar
    Sunny SoCal
    591
    Intermatic PF1102T Freeze Protection Timer with Thermostat or Intermatic PE153F Digital Clock Metal Enclosure Freeze Protection would be good choices. At least in the case of the digital unit, it will control a two speed pump for some energy savings. They will both also allow you to pick the times when power is cheaper to run your pump. Also, no more having to walk out to the pool pump area to turn it on.
    Pool done!! (backyard = work in progress) 32' x 19' inground freeform with 7' spa, baja step w/ (2) bubblers, stonescapes mini pebble finish, rock waterfall feature, 12" raised bond beam, Intelliflo VS, Whisperflo feature pump, (3) 5G Color LED's, FNS + DE 60, 400K Master Temp, Easytouch 8 w/ remote, Intellichlor IC40, Vision Classic Ceramic Kamado smoker, Margaritaville DM1000!!! Party Coming Soon!!
    TF-100 Test Kit w/ Speedstir
