Thread: Recommendations for PH automation
    I'm a bit tired of having to adjust my Ph every other day. My salt generator causes a bit of Ph drift, and adding acid all the time is a bit more than annoying.
    I'm sort of looking into some form of Ph automation, but I've come across two: Hasa Ph Adjuster and Pentair Intelliph. The HASA PH Adjuster is far less expensive and looks far more straight forward, but I've never heard of the brand before. Does anyone know if they're any good, or if they even work with salt systems?
    Dec 2009
    Central Massachusetts
    2,690
    Re: Recommendations for PH automation
    Whats is your TA?
    14,000 gallon IG, Vinyl. Hayward 3/4 hp superpump, Penatair IC40 SWCG, Pentair automation, Hayward sand filter, Aqua Comfort heat pump, Hayward 400k Lo-Nox LP heater.
    38,449
    Please add your location (City, State or City, Country) to your profile and pool details to your signature as described HERE as it will help us help you.
    There are 2 types of systems.
    One just adds a certain amount of acid at certain times ... you manually adjust it.
    The other has a sensor that tries to determine the pH and adjust the acid output accordingly. I believe these require calibration and may need periodic replacement of the sensor.
    I would CERTAINLY stay away from the combo systems that add an ORP sensor that try to automate the chlorine production as well.
    I would also not recommend a system that uses dry acid or CO2.
    As BK asked, What is your TA and what is the TA of your fill water?
    Adjusting this and possibly adding borates could reduce the pH rise rate.
    The IntelliPH requires that you own a Pentair SWG.
    I've heard mixed reviews of the HASA Ph Adjuster, some people like it, some don't. However, not many people own one, so there isn't that much to go on. I do know that if you have a variable speed pump the HASA Ph Adjuster is probably not a good choice.
    If you really need PH automation I recommend using a Stenner pump and a timer (or channel on your automation system) to add acid on a schedule.
    Chances are you don't actually need PH automation. Unless you have high TA fill water, it should be possible to balance your levels so that PH rise is not an issue. I have a SWG and it has been a couple of years since I added acid.
    Dec 2009
    2,690
    I have chlorine generator and i haven't added a drop of acid in 3 seasons. I keep the TA around 70. I add 2-3 pounds of 20 mule team to increase the pH every couple of months. I have more of an issue with lower pH than rising, but not much of one.
    Killer95Stang's Avatar
    Sunny SoCal
    592
    After adding borates, I only add acid about once a week. If it wasn't for my high CH fill water, I could leave the PH a lone a lot longer, since it stays pretty solid near 7.5. I just like having it between 7.2 - 7.5 to keep scale from becoming an issue.
    Pool done!! (backyard = work in progress) 32' x 19' inground freeform with 7' spa, baja step w/ (2) bubblers, stonescapes mini pebble finish, rock waterfall feature, 12" raised bond beam, Intelliflo VS, Whisperflo feature pump, (3) 5G Color LED's, FNS + DE 60, 400K Master Temp, Easytouch 8 w/ remote, Intellichlor IC40, Vision Classic Ceramic Kamado smoker, Margaritaville DM1000!!! Party Coming Soon!!
    TF-100 Test Kit w/ Speedstir
